Few questions about things seen in my engine bay
On my stock 87 3.2
1. Theres a little hole about halfway down the plastic elbow from the blower to engine tin. Looks like it may have been drilled, not molded in place. Is this stock? If not... can't see why it would cause anything catastrophically bad to happen? http://forums.pelicanparts.com/uploa...1375755317.jpg 2. What would make the underside of the AFM oily? The topside of my engine bay is pretty spotless but there seems to be a film on the throttle position switch and AFM. Could this be from the car being overfilled with oil at some point? http://forums.pelicanparts.com/uploa...1375755340.jpg |
OH boy that explains a lot. I saw that clip floating around unattached. Will re-attach pronto. Thanks.
The hole in the heater tube. There's a holding clip that goes there that holds the cruise control cable.
Just happened to see exactly that on this album: Photo Album - Imgur
Any advice on the AFM oily film? |
It's a Gray 10mm plastic cable clip.
(Omega shaped) Part # 477-971-851 Cooper |
The clip is in the pic in the bottom left corner. It slid down the cable.
| All times are GMT -8. The time now is 08:30 AM. |
