These are fuel injectors that fit all 3.2 DME 911s A google coupon search will get you $20 off a $200 or more Five0 order too. use FACEBOOK20 A little over $400 for six brand new Bosch injectors with coupon Or get the "Black-Ops M series injectors" (Siemens/Lucas disc injectors..they are a notable design) for $325 with coupon. Or spend near $180/$200 or more to have your 25 year+ old injectors cleaned:eek: |
FYI,
Injectors turned out to be pretty healthy. Still happy I had them re-sealed and cleaned. http://forums.pelicanparts.com/uploa...1381521274.jpg |
Had mine cleaned on my 80k mile 3.6L. Unfortunately the shop lost the before/after results, but no difference that I could discern upon reinstallation. I run techron through about once per year.
Another 3.6 owner with <100k miles sent his off and they were wildly out of spec. I would call it a "while you're in there" job. Not sure if the 3.2 has head temp sensor, but that can alter the air:fuel mix quite a lot and foul your fuel mileage on the 3.6. Mine runs rich and I haven't yet tracked it down. Better than lean I suppose... |
Sure does have a CHT sensor and I'm replacing it with a 2-wire as part of my rebuild.
I guess this is obvious (why make two castings) but I was for some reason surprised that each head has the threaded hole for the CHT. So you can run a 6-CHT setup if you wanna get wild. Or stupid. |
Had my 88 911 engine with 180K miles out for G50 repair, and while it was out, send injecters to Witch Hunter to clean / test. Report showed only minor improvement after cleaning (best pulsed flow from 105.5 to 108.5 cc improvement) but worth the $138 for peace of mind and new o-rings, filters, and pintle caps. Took almost a month, so plan accordingly.
| All times are GMT -8. The time now is 07:45 AM. |
