Always Be Fixing Cars
Is the cat heat shield SS or mild?
I'm guessing the cat heat shield on my 3.2 is some grade of stainless or it would likely be looking a lot worse by now... can someone confirm? I'm about to re-attach it and want to make sure there is nothing I should to to corrosion proof it before I do.
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 08-06-2013, 07:00 AM
cycling has-been
bkreigsr's Avatar
put a magnet on it
Old 08-06-2013, 08:10 AM
True, will do this afternoon.
Actually I had my magnetic pickup on it while I was looking for a dropped fastener. Funny I can't remember if it was dragging on the shield or not.
Old 08-06-2013, 08:12 AM
Rescuer of old cars
Arne2's Avatar
I'm pretty certain that mine is aluminum.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 08-06-2013, 08:17 AM
theiceman's Avatar
im pretty sure mine ...er ... was .... too ...
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 08-06-2013, 10:55 AM
cycling has-been
bkreigsr's Avatar
would the factory put a thin-gauge aluminum panel that close to a heat source?
Old 08-06-2013, 11:13 AM
Rescuer of old cars
Arne2's Avatar
It's not all that thin. But since I drove to work today, I went out at lunch to take a closer look. I now believe it is zinc-plated steel, not aluminum, not stainless. Appears to be signs of surface rust where ever it has been scuffed.
2018 718 Cayman 2.0
Old 08-06-2013, 02:20 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Mine is stainless on my '87 Carrera. Stainless, despite being called stainless, does discolor and develop slight corrosion. Salt and other debris can cause it to "rust."
Hit it with an abrasive pad (Scotchbrite red) and some degreaser and it will clean right up. Mine is a clean brushed/scratched finish now.
Kevin L
'86 Carrera "Larry"
Old 08-06-2013, 02:44 PM
