Porsche 911 engine weight
Hi.
Does anyone know the engine weight of the older Porsche 911 engines? Thinking about the 2.0, 2.2, 2.4 and the 2.7 engines. Anyone got a clue? ghia1969 |
About 450 lbs with HE, muffler and induction.
1973 Coupe Projekt X (AKA bunch o' boxes full of parts) |
Easily lifted by two people if it's just a long block.
Took 3 people for mine (complete). Very heavy and awkward to lift.
At 450 lbs for an early engine and approx 100 lbs for the 901 transaxle, the drivetrain is fairly heavy, especially compared to a 1000cc motorcycle engine that puts out 180-200 HP that weighs 165 lbs including the 6 speed transmission.
Current: 914/6 GT Conversion, Cayman Old: Many PCars + Formula Racecars |
Max Sluiter
True, but you are comparing technology from around 1963 to technology from around 2013, 50 years later. We've learned a lot in that time. What would a 1963 Triumph (if they made one then) put out?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
French Import
![]() ![]() It is good to see Triumph make bikes again ![]()
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Sure... Agree with different technology between then and now! Our engines are no lightweights.
But look at the Ducati Diana in 1963 with 30 HP from 250cc. Specific power is lot more than our early 911 engines.
Reiver
ever hear of a guy driving his Ducati Diana a quarter million miles without any engine work, just tune ups and oil changes? The last leak down I had on my 930-16 was between 3-8 on all pots after 30 years of driving.....drove it 1700 miles to visit a friend recently and got 23 mpg and drove it hard.
Max Sluiter
But we are talking horsepower per weight. Do you have a weight figure?
I seriously doubt that the engine and tranny combo on my 70 weighs much more than the 450 mentioned above. That would be without muffler. Two people can lift the engine alone. Done it.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
Per the 1973 spec book, engine weight w/o oil:
T- 183 kg, (402.6 lbs) E, S, RS - 182 kg (400.4 lbs) 915 gearbox w/o oil & starter - 54 kg (118.8 lbs) These would all be mag cases, and I believe (but have no hard evidence) that these numbers include muffler,flywheel, PP, clutch and mounts. Joe
Joe Frantz 73 911 T |
No, it ain't fair.
I can lift the Trumpy short motor solo, not quite with the head on. But the bike lift makes a handy engine lift for the 911. ![]()
cheers, Phil 84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies. |
