Electical Gremlins in 85 carrera
The 85 we found in a warehouse in St. Louis sat for most of the last 5 or 6 years. We replaced all of the gas & brake lines . This weekend I plan to do all the bushings in the shift linkage. It is driving really well , lots of power,straight and brakes well. It's also the only Porsche I own that doesn't drip a drop.
It has a small list of electrical gremlins. i'm wondering wether they are all independant or related. Oil level & pressure gauges both pegged at max Key symbol (red) on console usaully on electric door locks don't work Can't lock driver door by mechinical or electric means electric window switch on drivers side for passenger window doesn't work radio gets occasional heavy electircal interferance noise
52 356 coupe 56 speedster 63 356 Cab? 69 911T 69 912 beater |
Oil pressure sender is either broken or the wire is grounding somewhere between the sender and the gauge. Disconnect the wire and see if it drops. If so, then it's the sender. If not, then it's grounding someplace else and you'll need to trace the wire through the car (or run a new one).
Josh 85 M491 Coupe - "Fat Bastard" |
I would start with a remove/clean/replace of every fuse in the block, both front and rear. And an inspection of the grounds, including the trans to body strap near the starter.
Also, look for rodent wire damage, maybe something is chewed thru. Chuck.H '89 TurboLookTarga, 361k miles |
