1968SWTs's Avatar
to markvg - RS Flares
regarding markvg's post
RS vs SC flares
>>markvg
>>Whats the difference? Is there any?
put them together in a photo - not sure it helps at all
Old 08-02-2013, 11:56 AM
flares RS vs SC?
Personally, there is no difference unless...you're building a show piece.
They all weld the same and looks the same.
good luck...svaldez
Old 08-02-2013, 05:14 PM
well for others there is a difference
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 08-02-2013, 05:21 PM
Speed Dog's Chauffeur
Dodge Man's Avatar
What year is the body?
For early 70's the RS is the way to go. If it is a Miami Vice wide body and/or rag top conversion the SC/aftermarket is less $$$. A high quality installation is a must to keep from looking "HOMEMADE" on the rear fenders. IMHO. Keeping period correct gives the car better lines when only doing rear flares. Seriously look at the long term value of your 911 before hacking it up past the point of "no return from hot rodding". I have 30 years of experience to see what happened with my changes and the long term vehicle value implications & costs. If it is a numbers car & clean keep it pure(sell to a collector?) but if it is already a hot rod just knock yourself out!!! It is your $$$ so make yourself happy.
Old 08-02-2013, 07:08 PM
Devil Dog Mosport's Avatar
Hey Gents,
I am wanting to "widen" my sc with steel flares..Not too radical, but enough to get 16x9 / 265, 275 tires under the fender...
Where are places to find SC flares , steel , 8 or 9inch??
thanks
1984 Carerra 3.2L - SP911
PCA, SCCA, NASA, ComSport
Old 08-08-2013, 12:24 PM
Dodge Man's Avatar
Remember oil hose clearance on the inside
Len has the "over the top oil lines" so your wide tires do not scrub the oil hoses. Len made a set for SC70 that are nice.
Old 08-09-2013, 06:28 AM
Originally Posted by Devil Dog Mosport View Post
Hey Gents,
thanks
It sounds like you're willing to flare beyond what SC or RS flares might provide. If so and if possible, suggest sourcing wheels/tires first, then trial-fit/install flares to confirm adequate clearance (remove torsion bars to allow full suspension travel) You can also confirm inside clearance/interference with existing oil lines, camber/toe bolts, etc.
Sherwood
Old 08-10-2013, 10:44 AM
