Headers
Does anyone know how Rarly L8 mid-length Headers compare with European Racing parts from GT Racing.
I need some headers for a 3.0SC fitted with carbs and S cams and am looking for performance between 3-7000 rpm. |
Crotchety Old Bastard
It depends on the exact application Chris. Our medium length headers are designed for modified engines with extrended red lines. Your engine falls into that profile. It is important that the port size of the engine match the primary tubing size of the headers. We offer both 1.5" and 1.625" primaries. Merge collectors coodinate unrestricted flow. If your exhaust ports are stock size then the 1.5" primaries will preserve torque while allowing the top end to flow.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Are the GT Racing headers exact duplicates of the original George's headers?
Tru6 Restoration & Design |
Schleprock
GT Racing took over George's operation recently. George Narbel passed away not too long ago.
Kevin L '86 Carrera "Larry" |
Thanks Kevin, I had heard he had passed away. Have used his headers on a 3.2 matched with a Wong chip and couldn't believe the power increase.
I'm assuming you'd see similar results on 3.2 with Rarlyl8 headers. Problem is, have never heard from any source, actual data. Be it butt dyno or actual dyno using otherwise stock 3.2 with rarlyl8 headers and proper wong chip. This is certainly the set up I'm interested in.
2017 Toyota Tacoma TRD Sport(Hate it) 1965 Chevy Biscayne |
Rarly...if you installed 1.625's with anti-reversion cones in them...would it be an advantage overall...or would the primaries end up a little too big to maintain low end torque?
Bob
Bob Hutson |
