Question carrera electric gremlins
hi my carrera 3.2l will start,but ten minutes later try to start but no spark.also have intermittent backdrain of battery.i believe i am not alone with spark problem.have spent weeks looking.not funny when stuck in traffic.HELP ANYONE.is it dme,coil ignition switch? greetings from green ireland!
Old 08-09-2013, 05:09 AM
Check your DME for cracked solder joints, esp around the transistors that stand up from the circuit board on the aluminum heat sinks. The symptom of these going is sudden intermittant no-spark that usually comes on at some point as the car is warming up, or cause a no-start condition that also comes and goes.
Chuck.H
'89 TurboLookTarga, 361k miles
Old 08-09-2013, 05:15 AM
thanks chuck,any ideas on backdrain,can be 13amp and again intermittent
Old 08-10-2013, 01:42 AM
kodioneill's Avatar
Position and reference sensors can be intermittent. Battery drain could be many things it would be a good idea to do a "electrical draw" search.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 08-10-2013, 05:14 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1, note battery drains 6% per day, get a C-teck 3300 tender to maintain the battery
'85 Carrera Targa
PCA/POC
Old 08-10-2013, 07:55 AM
