Question 77 s rebuild
have any of you california pelicans heard of Motor Meister in Downey, Ca.
says he can rebuild my tired 77 2.7 for $2995 and time cert it. also 915 trany for $795
have 102,000 on this motor and leaks a good amount of oil on the exhaust. he says its definitly the studs pulling out and if i let it go much longer i'll do some serious damage to the engine. car runs ok but its been sitting for 8 yrs and i just started driving it again.
his web site is www.motormeister.com
any comments would be appreciated
thanks russ
Old 08-06-2002, 10:20 AM
DON"T DO IT!!!! I asked the same question a month or so ago and got nothing but negative from tons of people from this board.
Do a search on this subject, and you will see. you're also sure to get tons of replies to this. I'm glad I asked the same question.
2000 MR2 spyder
2001 ford Escape
Old 08-06-2002, 10:35 AM
I don't believe head studs are the cause of your oil leaks either.
could be your oil return tubes, which will leak on your heat exchangers. They can be replaced pretty easy. Do that first, then check other areas for leaks. But do not take your engine to them! My 77 2.7 had 101k miles on it, leaked like a siv. I replaced the oil return tubes, leak gone. Ofcourse then I ripped the engine out and sold it. Installing a 3.0. good luck.
2000 MR2 spyder
2001 ford Escape
Old 08-06-2002, 10:42 AM
oh boy here we go.....
Old 08-06-2002, 10:44 AM
Mark Wilson
Guest
Posts: n/a
Russ,
Check out this thread from Kurt Starnes.
Motor Meister thread
For more info about MM, you can use the search function and find out more than you want to know.
Best,
Mark
Old 08-06-2002, 10:55 AM
A proper engine rebuild for a 77 911S engine will likely cost $6000 to $8000; a 915 transmission rebuild $1400 to $1800. Beware of the low ball estimate. Jim
Old 08-06-2002, 12:04 PM
Irrationally exuberant
ChrisBennet's Avatar
Re: 77 s rebuild
...any comments would be appreciated
thanks russ
Russ,
MM is so notoriously bad that when I see a post like yours my first thought is "Is he trying to bait us?"
I would check for leaks in these places. You may need to clean the motor first. (I use a high pressure car wash.)
1. The oil pressure switch on the top of the motor.
2. The thermostat on the top of the motor.
3. Nut just under #1 cylinder. #1 is the one right next to the distributor. John Walker told us of a fix for this.
4. Oil return tubes.
Use this board's search feature for more details.
-Chris
Old 08-06-2002, 02:00 PM
Don't rebuild based on leaks! Check the head stud torque to see if the studs are stripped or broken. Your leaks might just be valve cover gaskets, or chain tensioner cover gaskets, or both. MM issues have been well documented here.
Old 08-06-2002, 02:55 PM
Thumbs up
thanks for all your help and sharing your knowledge.
i think i need to get close to some of the Charlotte pelicans who do some of their own wrenching.
thanks again for all your help
russ
Old 08-06-2002, 05:53 PM
