A arm retaining plate - does it come with tow eye?
i don't have a front tow eye so i want to buy the correct part.
i believe its part of the A arm retaining plate but its not shown in the pelican diagram/drawing? btw - wheres the rear tow eye on an '86?
Rich ![]() '86 coupe "there you are" |
*bump*
wayne??
Rich ![]() '86 coupe "there you are" Last edited by dickster; 08-04-2002 at 01:22 AM.. |
Here's a pic out of my SC's handbook. I assume the Carrera is the same!?
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
Not Quite Banned
The Carrera has a slightly different plate than the one pictured above. Since SC's are towed much more often, they had a much heavier 'ring' welded to the cap. The Carrera, on the other hand, rarely breaking down and only needing something to prevent a curb from hitting the front condenser has a plate that is welded to the cap. The plate has a hole in it, not for towing, but for aerodynamic purposes.
Let me know if you need a picture - Regards,
Thomas Owen 1972 911T 1972 911S |
He he
LOL
nice one, i think the one at pelican has the (smaller) ring required for the carrera
Schleprock
Right you are T.O. !!!!
Kevin L '86 Carrera "Larry" |
I think your terminology is off. I don’t think what you are referring to is a front “Tow Eye” but rather a "Tie Down" point for shipping or trailering the car to the track. The illustrated removable rear tow eye is only for getting the car out of the “sand traps” found on the outside edge of many racetrack corners. When your Carrara needs towing use a flat bed.
As far as Carrara’s being more reliable than SCs, as if! |
911 + 129 = JOB
Too many spelling errors in that last post for me to assume its a typo!
C A R R E R A
1989 911 Carrera Coupe 3.2 2012 BMW 135i M Sport "It is not how much power you have, it is how much you have left to spare!" |
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
