steering wheel up and down play 88 911
How far should the steering wheel move if you apply pressure up and down?
Is this the consensus for the fix?
Mitch Leland's Steering Wheel Bushing
One thread mentions a write up by John Walker. Anybody remember where it is or how to find it?
Rick
88 Cab
Old 08-15-2013, 09:13 AM
wolds's Avatar
Just installed Mitch's bushing and I can report that the install was simple and that the bushing works great. Warren
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 08-15-2013, 09:20 AM
OK I found one of his posts.
Steering wheel moves up and down
What are the pros/cons of doing it this way
Is this the corect part 928-347-739-02-M737
Rick
88 Cab
Old 08-15-2013, 09:34 AM
kodioneill's Avatar
Just did one yesterday it's a easy install.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 08-15-2013, 04:33 PM
kkkarpuk's Avatar
With my steering wheel the bushing was shot and Mitch's bushing was a simple and great upgrade. This alone did not completely fix my issues. I had movement of the whole column. The shear bolts that secure the steering column to the dash were so loose I could remove them by hand. Replaced the shear bolts with hex head bolts and it has been issue free for years.
Ken
Old 08-15-2013, 05:40 PM
Burnin' Rubber
Koizumi's Avatar
I got rid of the loose shear bolts a while back, too. I've got Mitch's bushing staring at me as I type...
How does one go about installing it with a Momo extended hub and a Snap-Off removeable Momo steering wheel? I assume I'll have to take the entire hub off but I'm wondering about the steering wheel alignment.
Old 08-15-2013, 05:49 PM
kkkarpuk's Avatar
Take the hub off, follow Mitch's directions..if the original has broken apart try to first remove and clean out all the little bits.
Ken
Old 08-15-2013, 05:54 PM
Burnin' Rubber
Koizumi's Avatar
Much appreciated, thanks!
Old 08-15-2013, 06:30 PM
