No more guido window tint....
I finally got around to removing my 80's vintage guido bluish purple faded window tint. Holy cow it looks sooooooo much better. Why didn't I do this sooner?
Borrowed a clothes steamer, came off easy. Piece of cake!
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 09-21-2013, 01:03 PM
Metal Guru
911nut's Avatar
I used a heat gun and some acetone to clean up the residual glue.
The PO had the glass wrapped with tint. It was under all the seals
It wasn't until I had the glass out to replace the headliner that I was able to finish the job.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 09-21-2013, 01:21 PM
4flyboy's Avatar
Tint Removal
Just did this myself last weekend.
Handheld electric steamer shaped like a small vacuum cleaner. Followed the instructions on a couple of threads from this board. Moved slowly and got it very hot and wet. Peeled carefully. On a couple of occasions the tint split into two sheets....double the process if you go too fast.
Also speedy removal will leave a glue residue.
Took a couple of hours to clear the whole car. Not hard, just patience and some contorting.
Thanks to the guys who wrote about the ease with which one can do this w/out spending a couple of hundred dollars.... Scott
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 09-21-2013, 02:34 PM
Obsessed
sobamaflyer's Avatar
Why the tint hate? If you live in the south it's survival.
Travis, sent from my Galaxy S3
'73 Mercedes 450 SL
'75 911 Targa (long gone, sniff..)
http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog
"Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!"
Old 09-21-2013, 05:29 PM
Artist Extraordinaire
tmsautoart's Avatar
another easy removal tip: tint hates Ammonia. Spray it with regular windex or diluted ammonia and cover with a garbage bag out in the sun. It will peel right off....with the adhesive.
Terry
83 911SC / 85 Omni GLH Turbo / 91 VW GTI 16v / 18 VW Golf Sportwagen /04 Audi S4/ 16 Audi S4
Old 09-21-2013, 08:07 PM
Banned
No doubt about that (and the darker the better)!
Old 09-21-2013, 08:18 PM
Tint hate????? Hell,
Why the Guido hate?
-Guido
Old 09-21-2013, 10:10 PM
No haters here..... I love tint, just not when it gets old and turns faded blue and purple and makes everything out the back window look like a Dali painting.
As for the guido's..... I could put the fuzzy dice hanging from the mirror back up!
Old 09-22-2013, 05:24 AM
