back-up wired wrong?
My back-up light stays on... I just put my 915 transmission back in, from a rebuld... do I have it wired backwards, or is the switch bad?
the pin inside the tranny/behind the back-up lite sw may be installed backwards..easy to check..I assume this has happened since you installed the rebuild..if so then remove sw. then reverse the pin inside..at least look into the possibility......Ron
| All times are GMT -8. The time now is 11:03 AM. |
