PorPete's Avatar
Send a message via Yahoo to PorPete
back-up wired wrong?
My back-up light stays on... I just put my 915 transmission back in, from a rebuld... do I have it wired backwards, or is the switch bad?
Pete
Fredericksburg VA USA
74 EURO Carrera (right hand drive)
82 Targa (left hand drive)
Old 08-05-2002, 10:05 PM
Cool
the pin inside the tranny/behind the back-up lite sw may be installed backwards..easy to check..I assume this has happened since you installed the rebuild..if so then remove sw. then reverse the pin inside..at least look into the possibility......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-05-2002, 10:27 PM
