Zeke's Avatar
Wasn't there at one time a jack donut?
A hockey puck thingy that you placed on the floor jack pad or cradle itself that kept metal from hitting metal? The one I remember had a hole in the middle.
I'm not talking about the saddle you put on your jack in place of the stock one. You can't take the pad off a race type jack. But, that's not the point either. I want a polyurethane donut to go on the saddle and keep it off the jack post.
I don't see one anywhere. It's not in the Pelican catalog at this time. I do see the non holed ones. The issue here is height. If you can't place the thing over the jack post, you can't slide a jack under there.
Old 08-15-2013, 12:12 PM
B15 AAL's Avatar
I bought as you suggested a hockey puck and drilled a 20mm hole in it with a hole saw. Cheap, easy and works a treat.
Old 08-15-2013, 12:24 PM
Zeke's Avatar
Cool, didn't think of that.
But, today's crop of poly pads are expensive! I thought these things were like 10 bucks. What's out there?
Old 08-15-2013, 12:57 PM
docrodg's Avatar
You could get a poly body bushing for a car or truck and use that. Some old chevy bushings are 3 or more inches diameter.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 08-16-2013, 05:28 AM
Sugar Scoops Rule :)
dave 911's Avatar
Yep, I bought some hockey pucks awhile back at Play-It-Again Sports for a few bucks each - works like a champ
Dave
_______________________________________________
'76 911S Targa
'62 VW Type 1 Sunroof
'73 914 2.0 (1st Porsche, gone long ago but not forgotton)
Old 08-16-2013, 05:56 AM
rfloz's Avatar
I cut three to four appropriately sized squares from an old inner tube and hold them to the jack w/ a couple of wire ties.
Bob F.
1984 Carrera Factory Turbo-Look
Old 08-16-2013, 10:20 AM
Send a message via Skype™ to Porboynz
What about the material a kitchen chopping block is made from? The white plastic/nylon type, whatever that is. Get a suitably thick chopping block and attack it with a hole saw, then quickly hide the evidence from she who must be obeyed.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 08-16-2013, 11:56 PM
HarryD's Avatar
I just use a hockey puck. You can pick them up used for $1-2 and fit great in the saddle of a floor jack.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-17-2013, 10:09 PM
