86 Carrera rough idle
Hi, I have a great "barn find" 86 cab but it has a rough idol. It starts up and fluctuates or just dies out. Any ideas would help ,thanks.
Old 08-17-2013, 04:31 AM
Banned
All kinds of stuff could be wrong. From simple to catastrophic.
I'll start.
No compression in one or more cylinders.
Old 08-17-2013, 07:56 AM
steely's Avatar
Any ideas as to how long since it has been since it was last run/started?
There is so much you may need to, but it isn't a really long list.
Maybe clean/replace the plugs.
Drain tank / flush the fuel.
Replace fuel & Air filters.
Replace vacuum lines to throttle body (TB) and check the others (to brake booster, charcoal canister, oil tank).
Maybe clean the injectors & TB.
more ideas will come or do a little search here.
Post a pic too, and good luck.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 08-17-2013, 07:57 AM
I'd start with the most probable first (and if the car hasn't been given a good 'ol Italian tuneup...do that FIRST) . Then...start by making sure your ICV (idle control valve) is functioning properly (search the archives...lots of info) and that you have no vacuum leaks. Both are common issues...
ps: Use search topics like "ICV" and "hunting idle"....lots of us have BTDT. Good luck!
Old 08-17-2013, 08:10 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1, everything these fine gentlemen stated.
General Location too, you may have some fellow Pelicans near by to take a peak for you :-D
Welcome aboard 3.2
Jim
'85 Carrera Targa
PCA/POC
Old 08-17-2013, 08:57 AM
WUNDERWAFFE
JINKATIN's Avatar
Don't forget cylinder head sensor.
Charlie
1986 Carrera
Old 08-17-2013, 03:53 PM
The cht was a problem I had with a cab I owned that sat for 8 years. As mentioned check the IAC.
Check for vac leaks also. Start with the easy stuff.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 08-17-2013, 09:38 PM
