Vent the gas cap on track car?
I have noticed that since I put in the 3.6 in my '87 911 there is a vacuum created in the tank. I notice this when I remove the cap to add fuel. Is there a reason I should not drill a small vent hole in the cap?
Once a friend of Cliff
ah, yeah, it'll leak.... do you have the stock tank or a cell?
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Stock tank, never more than 3/4 full. I'm thinking a 1/16" hole in the cap.
Northern Motorhead
Dennis,
I had the same issue after i removed the overflow reservoir and the headlight washer reservoir in the left front wheelwell after my 3.6 install.I had capped the line coming from the tank and the first time i went to fuel the car i was surprised as well to have vacuum in the fuel tank. Anyhow i removed the bolt i used to cap the line and all is well again,only issue was that i had a small leak from that line after i parked my car on a slope with a full tank ... I'm going to find a better routing for the line and maybe extend it and run it somewhere under the front bumper ! Cheers Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
I did that and almost spun out on my own fuel during a hard right hander!
Went back to stock setup for fuel vent.
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
I still have the stock overflow tank and plumbing in place. Where is the vent to atmosphere?
Northern Motorhead
Dennis,
I believe it's routed to the rear of the car and into the charcoal cannister in the right rear wheelwell.I had to remove the charcoal cannister when i installed my ER high clearance oil lines,they just wouldn't fit with the cannister in place.I also removed all the lines and hoses in the engine bay and installed a catch can for the crankcase breather and a separate small breather for the oil tank ... Did you plug any lines in the engine bay ? Cheers Phil
No new plugs. The PO removed the canister and plumbing to it. I will try to find where that canister line is cut/ plugged.
porsher
I have the gas tank vent with carbon canister.
However, I needed a place to connect the canister on the 3.6, see thread below. It works just fine, I don't see why you couldn't connect directly to the port and delete the canister. Do you still have the fuel separator, white plastic box next to the filler neck hose? Mine broke so I made a work around. Can post pics later if interested. 3.6 Fuel vapor breather
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
I still have the white plastic fuel separator and the hoses connecting to it. One goes to the tank, one connects to the fuel filler pipe, and one disappears under the wiring bundle. That must be the hose that formerly went to the canister? Does that hose go through the center tunnel to the rear wheel well?
Fuel cells and tanks absolutely require a vent to allow air in when fuel gets consumed. Check sanctioning bodies. Most specify a one way valve in the vent line.
Current: 914/6 GT Conversion, Cayman Old: Many PCars + Formula Racecars |
Source for one way valve to put in vent hose?
Northern Motorhead
Dennis,
I just ordered one today from HRPWorld ... it's a one way Fuel Safe fuel line vent valve,3/8 diameter and they're $14.00 dollars P/N FS-RV38 Cheers Phil
I drilled a very small hole in the underside of the cap to address this issue. My car is a '71 and had a 3.2 swap at the time.
I know I get lots of fuel sloshing up into the filler neck at the track but I've never had a leak.
Todd Doing business with leebparts? http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/555068-attn-leebparts-please-contact-me.html |
Thanks guys.
