Thumbs up Webber question – tuning success
Spent an enjoyable couple of hours tuning my carbs last night – to get rid of a rough and hunting idle. Very happy with the result and I’m now feeling very comfortable working on these.
My question: Whilst synchronising I noticed I had backed one of the air bleed screws out to its limit to get the right balance. All the screws appear to be a fair way out. Is there a starting point for one of the carbs to use as a base for the others? Ie. Should one of the screws be say X number of turns out and the others carbs balanced to match?
Thanks in advance
Regards,
Paul
Modified 1969 911T 2.4
1999 Audi A4 V6
Old 08-28-2001, 05:49 PM
avendlerdp's Avatar
Post
The air bleed screws are supposed to be in all the way to start. You set the carbs up with them all turned in and then open up the ones on the low flowing cylinders (at idle).
Old 08-28-2001, 06:19 PM
Post
Thanks for the tip.
Cheers,
Old 08-29-2001, 04:05 PM
