Looks like great progress Jeff. I didn't get mine out yet, Family stuff too and I had to deliver my 12 year Subaru RallyCross car that I sold to make way for the 911. Very sad about that :(
https://fbcdn-sphotos-e-a.akamaihd.n...97188271_n.jpg So, with just the oil line and speedo wire to deal with I thoroughly expect to drop this thing today. One question though: what is the best thing to drop it on? floor, dolly, tranny jack, floor jack, Matco tool box (remove tools first)? I'm leaning to the tool box as it is a good working height and has wheels on it. Just wondering if I need wood supports under the engine. Can I sit it all on the headers/heat exchangers? How much does the engine and trans weigh? |
Engine & trans weigh ~450 lbs. no worries about the weight being supported by the heat exchangers/exhaust
Jeff,
sorry to hijack you thread but mine is OUT. :D Decided to drop it on the tool box we don't use. https://fbcdn-sphotos-g-a.akamaihd.n...30098371_n.jpg Come on Jeff. catch up son. |
Nice Work! You beat me to it!! But not by much................ |
So I had a decent amount of time today.
Got the axles disconnected. Kevin, You were right. Those bolts were pretty easy to take out. I had some pipe laying around and used it as a breaker on top of a little "L" shaped hex wrench. http://forums.pelicanparts.com/uploa...1377390592.jpg Then I almost forgot the grounding strap. Darn thing was camouflaged with the undercoating and gunk down there. Also, noticed I forgot the the oil pipe! I didn't see that until I started dropping it (the first time) :eek: http://forums.pelicanparts.com/uploa...1377390680.jpg http://forums.pelicanparts.com/uploa...1377390723.jpg |
So, I mentioned above about the "FIRST" drop. I was using a some blocks I had laying around for supporting the car. Placed them on top of a dolly I use to stack the tires on and roll the around the garage.
Well the weight of the engine was too much for the dolly and it started to collapse. http://forums.pelicanparts.com/uploa...1377390901.jpg So I ran to Harbor Freight and grabbed one of these! They were even having a parking lot sale and I saved $40 bucks. http://forums.pelicanparts.com/uploa...1377391003.jpg Then it was much easier. Had to go back and forth to check the left axle and the throttle linkage. Also found that the speedo sender wires were a lot easier to pull through after the engine was lowered a bit. So I started cranking up the lift. |
success!!
That's awesome man. I need to take that picture too.
How much was that motorcycle lift? Looks like a great solution. |
Paul, it was relatively cheap, $80 at Harbor Freight on sale. Rolls around VERY easily but a little rough going down. Totally worth it.
Nice job dudes! Engines out w/out drama!!!!
Another solution is to use some serrated washers and "moon plates" under the bolt head. The later cars with 108mm CV joints and M10 bolts do this and it works good. Serrated washers are cheap by the 100 at McMaster McMaster-Carr and the VW plates are only $1.75 each (12 needed) TORQUE DISTRIBUTION WASHER [87-5081-0] - $1.75 : Vwbugworld, World Of Vintage Volkswagen When you use the moon plates, some longer CV bolts are needed to make sure you get plenty of thread engagement in the receiving threads. M8 x 50mm is the size you want. McMaster-Carr |
I have a ATV jack as well, but have never used it for a 911 engine. Always used the 2 jack method instead.
Pipe with L shaped wrench? You will need better tools than that on the way in, for sure. Good job nevertheless with the first drop. |
I have a decent set of allen head sockets but the boot made it pretty tight to get it on and off. A simple L shaped allen with a breaker bar worked very well. Once it was cracked loose, I just spun the allen wrench and off they came. |
The easy way to do that is with the wheels off the car, reach in with a super long extension and sit outside of the car to turn the allen bolt out. You reach the top 2 bolts at a time. Use a screw driver in a disc brake vent to keep the disc from turning.
+10 on the Sears ATV lift! I originally bought the Harbor Freight motorcycle lift, then bought the Sears to compare. Returned the HF, kept the Sears, much higher quality and modulates smoothly up and down. No contest!! He's a pic from the 3.6 removal from my '80SC. The red dolly was made by a fellow Pcar friend. When I admired it, he said "take it home, I can weld up another" great guy! It was originally made to use a floor jack slid into the "slot" at the back. You just lower the jack and rest the motor/trans on the dolly. When I found the Sears lift, I slid a HF furniture dolly under the steel dolly as it wasn't tall enough to slide the lift under. It all works smooth as silk. http://forums.pelicanparts.com/uploa...1377459196.jpg |
Here's a pic with the jack out of the dolly. I don't have the luxury of a car lift like you guys, but sometimes you just use what you have! LOL
http://forums.pelicanparts.com/uploa...1377459716.jpg |
Here's some better pics of the red dolly. The guy that made it built it to "industrial" grade!
Steel casters no less. http://forums.pelicanparts.com/uploa...1377465106.jpg http://forums.pelicanparts.com/uploa...1377465197.jpg |
| All times are GMT -8. The time now is 12:39 PM. |
