Engine with Haltech ECU just quits on track
Deleted
___________________
Steve- 62 356 S90 Sunroof-sold 11/16
73 911 No longer Targa-3.2L Running GT4
88 Carrera G50 sold 2019
2015 Cayman GTS
Last edited by SRT356/911; 08-20-2013 at 10:32 AM.. Reason: Don't want to cause problems for installers
Old 08-20-2013, 07:38 AM
schumicat's Avatar
if there are any crimped connections related to ecu or ignition I'd check those first.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 08-20-2013, 08:08 AM
deleted
___________________
2015 Cayman GTS
Old 08-20-2013, 09:47 AM
When I encounter a problem like this, I use a whole series of LED's to help me track down the problem. I have a plastic radio shack box I made with 8 LEDS and 8 resistors that I can setup to either track power or ground. For example, in this case I'd monitor input power to the Haltech, output power to fuel pump, pulse grounds to fuel injectors and coil(s), maybe even input sensors like crank position.
Then, with it all running, I have real-time status, and when the problem occurs I can instantly tell what is working and what is not; for example the power to the Haltech being cut from a problem with some external switch.
HTH,
Chuck.H
'89 TurboLookTarga, 361k miles
Old 08-20-2013, 10:30 AM
