-   -   Engine code (http://forums.pelicanparts.com/porsche-911-technical-forum/766921-engine-code.html)
911mania 08-19-2013 11:36 PM
Engine code
Does anyone know what engine is this? I have this engine number (7 Digit number) 64053**. And on heads I also have this number 901.105.111.0R
twistoffat 08-20-2013 12:20 AM
You sure its 640? the 6 is 6 cylinder and the 4 indicates a US 911 S between 74 and 78
The 0 as third digit would suggest a 1970 car but then the second digit should be a 1,2 or 3 to represent a T,E or S
djpateman 08-20-2013 08:45 AM
That depends, what is the engine type #?
930/07 would be a 3.0 L SC
901/38 would be a 2.0 L 914/6
I guess it is the latter one based on the head part #.
911mania 08-20-2013 02:48 PM
http://forums.pelicanparts.com/uploa...1377035296.jpg
911mania 08-20-2013 02:49 PM
this pic of my engine code on the casing top end ..
ossiblue 08-20-2013 05:44 PM
Someone can correct me, but the location of the engine # and the number sequence seems to indicate it is a 914/6 engine. 911 engines have the engine serial number stamped along the vertical support for the fan. The 914, being a mid-engine car, had the number stamped where it would be visible from the top rather than the rear.
Looks to be a 1970 2.0 USA version 914 engine.
djpateman 08-20-2013 06:21 PM
My guess (above) is confirmed.
