My other ride is a C-130J
RNajarian's Avatar
Targa movable vent window rubber replacement
I have searched the forum to no avail on the proper method to replace the window rubber on a 1975S Targa movable vent window.
Has anyone done this?
Any advice?
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 08-22-2013, 12:47 PM
Yes, the easiest way is to take the door frame out of the door and then remove the pivot so you can take the wing window out. Then insert rubber, put the quarter window back in and reinsert frame.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 08-22-2013, 03:31 PM
ROW '78 911 Targa
timmy2's Avatar
Just happen to be doing this myself before swapping them out for my stationary ones..
1. Remove entire vent window assembly from door, put it on a towel on your workbench.
2. Remove felt from main window guide channel if you are replacing it. (I am and it is really glued into these old frames!)
3. Remove bottom nut and clamp on the pivot of the window frame post and remove the 4 Phillips screws around the frame that are visible.
4. Remove window from frame and then remove the rubber. Clean and polish as needed...
5. Install new rubber and put it all back together.
6. Re-install or replace channel felt,
7. Re-install window assembly and adjust.
If you are replacing the small rubber tips (guides) at the top of the frame you need to do this while it is apart. Buy the tips and new rivets for it, then drill the old rivets out, install the new tip and install the blind rivets. (Find a tool for these rivets)
Good luck, hope this is helpful.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-22-2013, 03:37 PM
RNajarian's Avatar
Thanks for the replies guys . . .
Follow up question.
How do you remove vent window frame? Please tell me I do not have to remove door panel/handle etc...
Old 08-22-2013, 11:35 PM
ROW '78 911 Targa
timmy2's Avatar
Sorry, door panels and all required hardware have to come off to get the frame out.
Dennis
Old 08-22-2013, 11:41 PM
RNajarian's Avatar
$#!- !! I just had them off for another issue.
Thanks for the help
Old 08-23-2013, 12:02 AM
ROW '78 911 Targa
timmy2's Avatar
Well, at least you know how to take it apart!
Old 08-23-2013, 08:19 AM
To replace the window stops you must also separate the vertical portion from the vent frame to be able to drill out old rivets and insert a buck in the channel as a counter.
1991 C2 Turbo
Old 08-23-2013, 08:46 AM
