Carfax Request / 914-6
COULD SOMEONE HELP ME WITH ......
1970 914-6 { 9140430862 } HAS TWO FACTORY 914-6 ENGINES ========================================= 1967 - 68 912 WIDE BODY W/ STEEL FLARES ALL ROUND { NR460932 } KUNSTHARZLACK {68-6606-C } THANKS K.T. 1973 911E 2.4 MFI 1967 DEVIN 912 POWER PLANT |
I believe car fax only goes back as far as 1980 or so. I tried to find one for my 77 911, that's when I found out.
Tom
2000 MR2 spyder 2001 ford Escape |
I believe it is '82 for their database. At any rate, anything other than a now-standard 17 digit VIN will not work at all. If you're looking for a 70's p-cars you're out of luck...
IS THERE ANOTHER WAY I CAN FIND OUT SOME HISTORY
ON THEASE CARS? |
Is this a CA. Car? if so, you can go to the DMV home page and
possibly find some info on it. I found some brief info on my 77 911, but it was just smog related. Other than that??
You may very well be able to go to your local dealer and have them run the VIN on the dealer communicate system. At the very least you should see what took place up until the warranty expired.
the Rat |
That would be what, about 6 months after purchase?
912 / 914-6 KCMO
OK, THANKS FOR ALL YOUR REPLIES.
BOTH CARS WERE FOUND HERE IN KANSAS CITY. MY TWO BROTHERS BROTHERS EACH OWN ONE OF THEM NOW. AND I WILL GET TO DRIVE THEM AFTER THEY DUMP SOME MONEY ITO THEM. K.T. 1973 911 E 2.4 MFI 1967 DEVIN 912 POWER PLANT |
