Slight front end knock
My 83 911SC has a 163k on it. Best heard when shutting the engine off and coasting at low speeds, she has a slight knock freom the front end. I can hear it only at lower speeds and on less than smooth pavement. I have been slowly rebuilding it and had planned on getting after the suspension this winter, but I'm a bit concerned of doing damage or suffering a roadside incident. Any thoughts? I replaced a shock tower bushing but that was not the culprit.
the Rat |
this is common on bilstein struts. the metal bushings inside the strut tube, which guide the shock body, get sloppy. bilstein can rebush them i believe.
Thanks for the response. If it wasn't for the 3000 mile distance, I'd be a regular customer out there in Seattle. Your experience is enviable. Cheers.
the Rat |
