BSCR 914 (guest)
Guest
Posts: n/a
Fluid seems to be down 1/2 to 3/4 inch from side filler plug when we check it and tranny fluid has leaked all over tranny.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-20-2013, 04:48 AM
Nick at Pelican Parts's Avatar
Can you share a photo of the vent location and orientation? I opened a thread in our forums for this discussion.
- Nick
pete3799's Avatar
The breather should face the front of the car ( contrary to what would seem normal).
Pete
79 911SC RoW
Old 08-20-2013, 04:58 AM
Reiver
Reiver's Avatar
"The breather should face the front of the car ( contrary to what would seem normal)."
Exactly, there is a vacuum created while driving and if the vent hole is oriented anywhere but forward (toward the cab) it'll suck out your fluid.
Old 08-20-2013, 10:31 AM
No, it's actually because the breather has a down tube on the inside that has a fishtail cut on the end. If it isn't oriented correctly the ring gear(?) splashes oil on it and it comes out the breather.
Scott
'78 SC mit Sportomatic - Sold
Old 08-20-2013, 10:51 AM
Vintage Owner
Jack Stands's Avatar
Trans vent
I had the same issue when I converted my 914-6 to a 915 trans. When the vent is incorrectly oriented, it really does make a mess on the outside of the trans!
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 08-20-2013, 01:22 PM
Thanks all. Since I have turned the 911 engine and 915 tranny around to put in the 914 can we turn the breather to face the front of the car without causing problems? Jack Stands-seems we may have a similar project-may have more questions for you.
Old 08-21-2013, 03:14 PM
djpateman's Avatar
Welcome to a fellow Canadian, and 914 owner.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 08-22-2013, 10:26 AM
Vintage Owner
Trans vent
Good luck! Turning the vent 180 degrees once the R&P is flipped should take care of it.
84 Targa (sold)
70 914-6 (sold)
2016 Cayenne
Old 08-22-2013, 11:50 AM
Smile
Upon first tests problem seems solved. Thanks again to all.
Old 08-23-2013, 04:15 AM
