-   -   3 unconnected items in the engine compartment. Any help as to where they go? (http://forums.pelicanparts.com/porsche-911-technical-forum/767443-3-unconnected-items-engine-compartment-any-help-where-they-go.html)
hpmad 08-23-2013 12:55 AM
Hello,
I just finished changing the sparks on my car (as part of my attempt to fix the bad running, which was caused by the failed OXS relay).
the car is a 1980 911 SC
As I did this, I noticed 3 items in the engine compartment that are not connected to anything. This seems strange and I was wondering if any of you knew what they were and where they went...
http://forums.pelicanparts.com/uploa...1377244279.jpg
in this first picture, the 2 items are a nipple on the left side of the air box. This is opened to the air, by passing the filter, which seems strange... is it suposed to connect to something or should I plug it?
The 2nd item is a hose, which seems to be comming through the back wall toward the font of the car. No clue where it connect on the other side and no clue where it should connect on the engine side...
http://forums.pelicanparts.com/uploa...1377244317.jpg
In the 2nd picture, the offending items is a disconnected 2 prong connector comming from the wireing harness that splits under the intake manifolds on the left side of the engine...
any clue what that one might be?
Thanks,
Cyrille
blucille 08-23-2013 03:56 AM
The air box ports are indeed plugged, they appear o have a hole in them, but are actually depressions.
The hose looks like remnants from A/C
T77911S 08-23-2013 04:02 AM
i was thinking cruise control for the cable.
the electric plug is not used
hpmad 08-23-2013 04:04 AM
Hello
That one has actually a hole in it.. I was able to pass a small nail though it :-(
I have a working A/C... but I will look to see if something got disconnected.
cyrille
ManniB 08-23-2013 04:09 AM
The hose is most probably from the charcoal canister located on the right side in front of the oil tank in the engine bay. It is plugged into the nipple that you've circled. The electrical connector is not used in your year 911.
- Manfred
hpmad 08-23-2013 04:10 AM
Thank you!
Cyrille
T77911S 08-23-2013 06:31 AM
the black cable looks like it has a cable going to the throttle. something for a cruise, maybe "poor mans cruise" i dont know what the factory cruise looks like.
plug the air box hole if it is open.
