Front Spindle Spacer O-ring size problem
The o-ring, that goes between the front wheel bearing spacer and the front spindle, is listed as 25.3mm ID in PET. PP sent me the 25.3mm o-ring.
But the spindle is ~39mm in diameter. I think this is an error by Porsche; the o-ring sent is way too small. What is the correct size, and where do you get them? |
Just pick them up at the dealer,they're not that expensive ...
I had to replace my bearing spacers last year,those were expensive !!! Cheers Phil |
If it's the o-ring I'm thinking of, mine seemed way to small aswell. It stretched quite a bit.
I ordered it from the dealership by the OEM part# |
Did you have to stretch a small oring too?? |
I was wondering also. The same O-ring is listed for the speedo drive, and this is way smaller. However I had a few in stock, so I looked at fitting it. The conclusion I came to was that it really needed to be stretched. Would like confirmation though.
When I installed mine, I believe I just rolled it up the spindle till it was in place. It stretched itself. Once you put that metal spacer back on, the o-ring is never seeing the light of day again.
Like the boys above,it was a tight fit and then it disappeared once i put the spacers on !
Cheers Phil |
It sounds like this oring is a real oddball.
Normally you would never try to stretch one so much. |
I bet o-ring is intended to stretch to clear fit between fillet on spindle & the collar?
I too noticed the stretch when installing spindle spacers for my VCI brakes |
And so it seems this little oring is the correct solution to adding a little bit of sealing to the spacer ring.
Thanks to everyone who responded! |
| All times are GMT -8. The time now is 03:09 PM. |
