VFR750's Avatar
Front Spindle Spacer O-ring size problem
The o-ring, that goes between the front wheel bearing spacer and the front spindle, is listed as 25.3mm ID in PET. PP sent me the 25.3mm o-ring.
But the spindle is ~39mm in diameter.
I think this is an error by Porsche; the o-ring sent is way too small.
What is the correct size, and where do you get them?
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 08-24-2013, 07:03 PM
Northern Motorhead
wildcat077's Avatar
Just pick them up at the dealer,they're not that expensive ...
I had to replace my bearing spacers last year,those were expensive !!!
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 08-24-2013, 07:50 PM
300hp 1800lbs is the goal
pksystems's Avatar
If it's the o-ring I'm thinking of, mine seemed way to small aswell. It stretched quite a bit.
I ordered it from the dealership by the OEM part#
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 08-24-2013, 08:36 PM
VFR750's Avatar
Cheers
Phil
Phil,
Did you have to stretch a small oring too??
Old 08-25-2013, 06:49 AM
djpateman's Avatar
I was wondering also. The same O-ring is listed for the speedo drive, and this is way smaller. However I had a few in stock, so I looked at fitting it. The conclusion I came to was that it really needed to be stretched. Would like confirmation though.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 08-25-2013, 10:48 AM
pksystems's Avatar
When I installed mine, I believe I just rolled it up the spindle till it was in place. It stretched itself. Once you put that metal spacer back on, the o-ring is never seeing the light of day again.
Old 08-25-2013, 10:58 AM
Air Cooled
Craig_D's Avatar
+1 to this. Mine was exactly the same...I had to roll it onto the spindle to stretch it into place, and then install the metal spacer.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 08-26-2013, 11:12 PM
Northern Motorhead
wildcat077's Avatar
Like the boys above,it was a tight fit and then it disappeared once i put the spacers on !
Cheers
Phil
Cheers
Phil
Old 08-26-2013, 11:42 PM
VFR750's Avatar
It sounds like this oring is a real oddball.
Normally you would never try to stretch one so much.
Old 08-27-2013, 03:55 AM
KTL KTL is online now
Schleprock
KTL's Avatar
I bet o-ring is intended to stretch to clear fit between fillet on spindle & the collar?
I too noticed the stretch when installing spindle spacers for my VCI brakes
Old 08-27-2013, 07:50 AM
VFR750's Avatar
And so it seems this little oring is the correct solution to adding a little bit of sealing to the spacer ring.
Thanks to everyone who responded!
Old 08-28-2013, 04:11 AM
