Performance chip
Hi!
Does anyone have any experiance with this chip from www.PowerPROM.com ..... FR Wilk chips ..... ©2010 FR Wilk ? All input will be appreciated :-) Regards FMO |
hmm
bump :-)
ASE Master Tech - 35 yrs
i just installed the powerprom 911 racing chip for an 050 DME 2 days ago -
better idle, maybe "snappier", bought it on FRW's advice 'cuz i have no 02 nor CAT - downside is that the mid-range timing curve is too aggressive for my use - lots of pinging on half-to-full throttle at low rpm (under 3000), when lugging or pulling uphill in 4th-5th that's on 91 octane AKI USA gas - you may have higher octane available - like they say "it all depends on how you plan to use it" - if you are going racing & use track gas - go for it my stock 082 DME pulls like a train under same conditions, & will pull uphill from 1500 rpm w/o a whimper in 5th, my 050 dme performs same as the stock 082 after i replaced the powerprom with the stock chip i decided to try the powerprom, thinking the dead 02 circuit might be a "constant full rich" problem (apparently an incorrect assumption on my part - Wilke says that the DMEs do not "go full rich" in the way that OBD cars do, so i was worrying about nothing important - C'est la Vie)) (i'd already resolved the potential vacuum leak issues and have none) I have a question in to FRW as to whether retuning the FQS will resolve the pinging issue stay tuned fwiw - i swapped in a Innovative-autosports 911 racing chip ($49 on eBay) in another 082 DME - and the car runs fine on it - i'll report more after i get a few-hundred k's on it Quote:
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
I did convert a 24-pin DME to fit his 28-pin "shudder fix" chip for a buddy with a series 1 944 who didn't know what end of a soldering iron gets hot; it did exactly what it said on the tin.
'77 S with '78 930 power and a few other things. |
Chip
Ty for the replies. I will order one chip from him today :-)
Regards FMO |
i have 5 wilk chips they are the best , i live in las vegas it gets 115 temp hear, no pinging buy the best 91 gas, some thing is wrong with your engine
nothing wrong with my engine
- i have 4 good 3.2 dme's and have test driven all of them on the same hilly circuit with the same gas - all drive perfectly, no pinging as a test, as advised by Floyd via eMail, I pulled out the 911 racing powerprom & replaced it with the stock chip in that same dme - it drives perfectly on the same roadtest circuit - the only chip that does not "work" for street driving in my '89 3.2 is the 911 racing powerprom as a further comparison - i bought the $49 eBay Innovative-autosports chip - put it into a good 082 dme - and it works fine, with no excessive advance issues like i had with the powerprom - it pulls nicely from 1500 rpm in 5th on an uphill grade at full throttle without any pinging - (just like all 4 of my oem dme's will do) - at altitudes of 4000-5500' it exhibits a slight "tip-in" pinging in the 2200-2800 rpm range, but that goes away at higher altitudes (as one should expect given the lesser cyl fill density) and here's the rest of the story - fuel consumption: - results for over 1200km of combined urban, hill country & freeway driving - (same combo for each setup) oem chip = 24 mpg over 800 km powerprom 911 race chip = 18 mpg over 200 km innovative chip = 24 mpg over 400 km i will grant that Floyd's chips have a good reputation in the 944 crowd - that is why i bought it - but the one i got is not any good for street-touring use imho - ![]()
Me too. I just ordered one for my 89.
1989 Porsche 911 Carrera 1984 Porsche 944 (with PowerProm & dual chip adapter) |
Performance chip
Hi!
I have installed a performance chip from powerprom.com. After some small issues and very good help from FR. Wilk , a real gentleman. My car is running very Nice, With better trottle response and a really kick from approx 3700 rpm ->. Thanks to Fr. Wilk, for a good Product and very good service. Regards FMO |
