Talking ignition
1987 carrera..
I have not changed my distributor cap and ignition rotor and wire set for over 10 years...car runs well!
75,000 miles.
1. do you believe that I should change those as a preventative activity?
2. does any one has a step by step procedure (with pictures if possible ) on how to lubricate the distributor?
Old 09-01-2013, 12:02 PM
non-whiner
mreid's Avatar
Definitely change them. Not sure what you mean about lubing the dizzy.
"Too much is just enough."
Old 09-01-2013, 12:21 PM
lubricating the dizzy
some threads talk about oiling the felt...I do not know where the felt is or how to find it...this is what I mean by lubricating...any instructions? or suggestions?
Old 09-01-2013, 12:27 PM
Autodidactic user
David E. Clark's Avatar
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 09-01-2013, 12:38 PM
non-whiner
mreid's Avatar
Aha, that point. Be stingy with the oil. One drop is plenty.
Old 09-01-2013, 12:53 PM
E Sully's Avatar
Make sure the felt pad is in the center, I like 4-6 drops, just make sure it has the dust shield installed. Make sure it doesn't look like this under the rotor. DME sets the timing, but the centrifugal weights keep the rotor aligned.
Ed
1973.5 T
Old 09-01-2013, 12:54 PM
ignition
Thanks guys..glad you added some pictures
Old 09-01-2013, 04:31 PM
RETIRED
Joe Bob's Avatar
What about oil and brake fluids?
2012 ML350 3.0 Turbo Diesel
Old 09-01-2013, 04:37 PM
AutoBahned
RWebb's Avatar
the pics show something that is not an adequate long term service for the distributor; it is a yearly service item only
you need to use the site's search facility and find a long thread by the late Warren Hall, who posted as Early_S_man or something similar
that thread should also be referenced in the long term maintenance thread
Old 09-01-2013, 04:39 PM
