Jupiter 911
Vacuum line?
After recharging my AC , I noticed a braided vacuum line lying down unplugged on the right side of the engine compartment. I cannot locate where it has come from, the other end is plugged into the base of the the throttle body then runs along the back of the engine and was lying close to the oil fill neck. Spent two days checking but cannot find where it has disconnected from! Thanks Lenny
Lenny-1987 3.2 Targa Guards Red/SW Chip Fabspeed Exhaust/Cat bypass MSDS Inc. intake/Clewetts Euro pistons and cylinders. 2002 Boxster Artic Silver/Wifes ride. |
Charcoal canister? Just guessing...
Chris '75 911s Targa |
Probably from the 'Temperature Switch' on the throttle housing (see below)
http://forums.pelicanparts.com/uploads22/268+Motor+Vaccum+Switch1377187922.jpg The end in question goes to the 'Air Valve' located above the 'Vacuum Limiter' on the 'Oil Tank' (look at your Emission label located on the underside of the engine lid--) If you need more help just take a picture of the 'Oil Tank' hose connectors and I will guide you further-- Cheers.
1995 993 ('Under my Care') 1989 911 ('Go Pitt') 1996 993 ('Go Navy') 1984 911 ('Go Pelican') Last edited by Jascha; 09-01-2013 at 07:02 PM.. |
83 911 Production Cab #10
Pics are your friends... Close-up & one with an identifiable datum.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Line?
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
One of the braided lines/tubing attaches to the side of the Air Box --
(remove the air filter cover and you will see it) Happy Labor Day!
1995 993 ('Under my Care') 1989 911 ('Go Pitt') 1996 993 ('Go Navy') 1984 911 ('Go Pelican') |
Jupiter 911
Thanks guys, found it 86 911,s pic was it. I seen the two black lines connected but did not notice the nipple for the braided line. Thanks and happy Labor Day!
