Droning Noise - 911 SC
Hi Guys,
Car is 79 SC with new wheels/tires.
When I steer a BIT to the left (hardly at all) I get a loud droning noise from the rear end. This is whether the car is in gear under power or in neutral and coasting. If I turn the wheel a bit the right of center (or just about center), the droning noise goes away.
I'm really stumped, any ideas???
'79 SC
Old 09-03-2013, 11:32 AM
Eva
911SauCy's Avatar
Wheel bearing
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 09-03-2013, 11:43 AM
RETIRED
Joe Bob's Avatar
Or CV joint. Does it increase in each gear or is it constant?
2012 ML350 3.0 Turbo Diesel
Old 09-03-2013, 11:53 AM
Yup. The classic sign of a bad or loose wheel bearing. A total pain, but not the end of the world.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
The droning sound changes as the speed changes, the frequency gets lower at slower speeds.
Is there a way to determine which side? i.e. if turning left (A bit) causes the sound then does that indicate a particular side?
Thanks for the help so far!
'79 SC
Old 09-03-2013, 12:59 PM
Eva
911SauCy's Avatar
It could indicate a particular side but IMO this is something that when you do one you do the other.
Chew on that idea
Old 09-03-2013, 05:18 PM
RETIRED
Joe Bob's Avatar
Wiggle test?
Old 09-03-2013, 05:19 PM
