Driver's window: difficult down, easy up
Long time lurker just got my first 911, an 86 coupe.
The day the car arrived I was checking every thing out and found the driver side window went down but wouldn't come up. Took the door apart, turns out the motor is non-op, replace the motor put door back together and find it goes down vey slowly, seems like its struggling, but it goes up with no problem. Is this the window regulator? |
See if it works better when you apply gentle pressure to the front or rear edge, the glass might be tilting in the frame on the way down. Strange though, usually a problem in the other direction when you are working against gravity.
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
mph911
It might be catching on the felt runners, check their condition.
Matt Hart - Instagram @the_escape_road |
new felt time.
Thread Tools | |
Rate This Thread | |
Tags |
window motor |
