Super Moderator
cstreit's Avatar
Can a Euro 930 be retrofitted?
Gang,
Can a Euro 930 (82) be retrofitted with emissions equipment to pass state emissions requirements?
I'm hoping not to assist in getting a waiver...
If not, why?
If so, how?
Thanks!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 08-07-2002, 10:35 AM
Crotchety Old Bastard
RarlyL8's Avatar
Sure it can be done. But I wouldn't want to.
What smog requirements do you have up there? Visual, sniffer, both? The Euro can be tuned to pass the sniffer. The visual will cost you a grand in used parts and at least 35hp.
If this becomes an unfortunate reality for you I have all the parts you need. Or - you could just move a few miles south (my vote).
Old 08-07-2002, 11:18 AM
Super Moderator
cstreit's Avatar
Rarly,
THere is no visual if you pass...
SO... How do you pass?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 08-07-2002, 12:04 PM
RarlyL8's Avatar
Lean it out.
I don't know what CO target you would need, <1.5 I would think. Find out the requirements for CO, NOx, and HC. You can then pinpoint a spot on the curves for these items and tune accordingly.
(Look at me giving advice when my own car doesn't run right yet).
Old 08-07-2002, 02:29 PM
Super Moderator
cstreit's Avatar
THe real issue is that emissions are way off across the board.
HC standard is 2PPM, mine is 7.16
CO is 60PPM, mine is 218
In fact, the CO was so bad, it didn't even show up on the printout...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 08-07-2002, 02:56 PM
Super Moderator
cstreit's Avatar
So what I need help with are the reasons that a Euro 930 CAN'T be retrofitted!
Can anyone help?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 08-08-2002, 09:33 AM
beepbeep's Avatar
Well you can always dilute gasoline with alcohol...people usually do that here in sweden when their car isn't going trough... :-)
You'll get much lower CO then...
Fine-tuning of mixture and ignition-timing together with cleaner fuel will certainly get it trough...
Funny thing is that my stock euro 930 get's 0.1% CO @ idle ,and 4.5% is max allowed
Thank you for your time,
Old 08-08-2002, 09:50 AM
CO is in %, HC is in PPM. so what are your readings again?
206 637 4071
Old 08-08-2002, 11:06 AM
Super Moderator
cstreit's Avatar
My readings are Hydrocarbons 7.16 (GPM)
and CO 218.6 (GPM)
CO2 is 400.3
THe CO is off the charts!
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 08-08-2002, 11:48 AM
here in washington, we're not familiar with the GPM thing. (grams per what?). we still do percentage. did the tech try to turn down the mixture with an allen wrench when it was on his gas analyzer? high HCs are often just a byproduct of high CO.
206 637 4071
Old 08-08-2002, 12:42 PM
beepbeep's Avatar
CO is notoriously unstable on theese cars...when i smoged my car with semi-warm engine it showed 5% CO = too much...
I sent it to the mech (for some other reasons ) and asked them to adjust CO, he told me "there was nothing wrong with CO, just warm up the engine..."
So i drove like a idot before smog check and voilá: 0.1% CO ...
on the other hand, low CO means lean mixture, wich means high combustion temps, which means high NOx , but i doubt they check NOx on our cars.
Here they only worry about CO at idle...i bet my car spews death as soon as i step on the accellerator
Old 08-08-2002, 12:46 PM
Super Moderator
cstreit's Avatar
They check the car on a dyno, CO and Hydrocarbons. I had taken the car for a 20 minute drive on the highway prior to the test. It was warm.
I think part of the issue is that the tester was lugging the motor, adding lots of unburned fuel....
SO... What I have to do is get a waiver, to do that, I need to
1) Prove the car was legally imported. (I have that documentation)
2) Document that the car is NOT able to be retrofitted ...(THis is what i need help with)
3) Make sure on the retest the car shows "SOME" improvement in emissions.
Beg and plead
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 08-08-2002, 01:19 PM
RarlyL8's Avatar
I don't know how much this will help your case, but just HOW FAR do you go before you can claim "unable to retrofit"?
Anything can be done.
In this specific case the retrofit IS NOT a bolt on. The reason is the air injectors that screw into the heads. New heads or machine work would be required to use the stock system.
Old 08-08-2002, 02:29 PM
Super Moderator
cstreit's Avatar
Well that's just the thing:
If I can show that it is not REASONABLE to retrofit the car (for instance, air injectors requiring head modifications) then this adds to my case of getting a waiver...
So there are a few things that should help
1) There is no oxygen sensor, right? No system to handle it.
2) No air injection on heads or facilities for air pumps
3) Catalytic converters, did the 82 930 have them?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 08-08-2002, 02:40 PM
Go to the dealer and get the list prices for all the parts that you would need to retrofit. For example I think the turbo inlet pipe lists for $2200 or so. That should help your case. Then lean out the mixture alittle before retest.
Good luck
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 08-08-2002, 06:01 PM
Euro 930 all have air pumps and air injection as stock, of course, most of them don't work or have been removed. Refitting the parts that were there in the first place isn't going to be difficult.
German versions were available with a catalyst.
Your local technician should be able to "adjust" the engine to pass any smog test.
If the CO is off the charts there is SOMETHING WRONG with the engine.
When I lived in Europe, we usually set 930 at about
3 - 5% CO with the air pump disconnected. The pump drops the CO about 1 - 2% The HC and CO2 readings should stabilise to normal.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 08-08-2002, 06:32 PM
Super Moderator
cstreit's Avatar
Hmmm... I wonder if there's a place that I can borrow a CO tester for a few days...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 08-09-2002, 05:59 AM
