Porsche Enthusiast
rsnodgrass's Avatar
930 brake caliper & rotor weights
I've searched through various forums and there doesn't quite seem to be a consensus on the actual weights of the front and rear calipers used on the 930.
Caliper weights without pads:
A-type aluminum front ('76-'77 930 Turbo) : 9 lbs 8 oz (9.5 lbs)
M-type cast iron rear ('76-'77 930 Turbo) : 6 lbs 12 oz (6.75 lbs)
917-style aluminum front ('78-'80 930 Turbo) : 8 lbs 6 oz (8.38 lbs)
917-style aluminum rear ('78-'80 930 Turbo) : 8 lbs 5 oz (8.31 lbs
Is this what other people have concluded as the caliper weights as well?
Rotor weights have a bit more variance:
A-type front ('76-'77 930 Turbo) : 9 lbs 8 oz (9.5 lbs)
M-type rear ('76-'77 930 Turbo) : 9 lbs 8 oz (9.5 lbs)
917-style front ('78-'80 930 Turbo) : 13 lbs 3 oz (13.2 lbs)
917-style rear ('78-'80 930 Turbo) : 17 lbs 3 oz (17.25 lbs)
Sources:
930 Front Brakes With M Rear Caliper
Brakes
74 Carrera 2.7 | 75 Turbo 3.0 | 97 Boxster | 12 Cayenne S
GONE >> 04 GT3 | 75 Carrera 2.7 MFI | 76 Carrera 2.7 MFI | 77 Turbo Carrera 3.0 | 86 Carrera 3.2
Old 09-05-2013, 08:03 PM
