reference sensor
Is there a way to test with a multimeter a reference sensor for a 3.2 as well as a speed sensor (identical as far as I can tell).
If so, what am I looking for? Ohms? Hz? voltage? It appears the middle pin is not used, rather it ties to a shield wire. So, it would be 1 and 3 pins that I am inquiring about. fwiw- I put a mm to a reference sensor while cranking and I got 4hz, 4 volts, but didn't get to Ω. Had to get to a pool party per the "Mrs" Thank you in advance, John
John- 78 Slick Top 930 "Illegitimi non carborundum" |
You want to measure resistance (ohms). But even when in spec they can fail when warmed up. If the car has high mileage I would replace them. What's the problem with the car?
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
vince_wa
John depends on whether sensor is installed or on hand. The sensor is an imbEdded reed switch with high power magnet. The manual advises how to test when installed and running - 2v sine wave on oscilloscope but I guess if it working why would you need to test it unless you suspect it's intermittent.
If you are testing on a workbench a ohmmeter with a piece of magnetic metal to trigger switch will give you a basic test result. I replaced mine (87) simply because of their age and they switch on every revolution - car is 25 years old so not replacing them was inviting a breakdown. When I removed them all the insulation was broken down due to location near exhaust. They are identical units These are cheapish! - you only need to buy the cheaper version for BMW or the 928 about $70 from pelican. Use the search tools - there is heaps written on this issue
Garage - 1987 911 widebody |
Ref
This is why I am looking at the reference sensor. I looked in the Bently manual but apparently missed it. I have searched but e is a ton of stuff on "my car won't start" I am looking for a specific item. I will search and read further. The sensor is in the car. I have another used sensor which is why I wanted to test. No point in putting in if it's shot. Do you have a part number on the cheaper ref sensor? John
i dont have the answer you are looking for but am going to ask this question to provoke more discusion .
On some vehicles the speed and reference sensors not only indicate when the crank and cam are at specific positions to fire the spark , these sensors are also used to fire the injector pulse for the fuel injectors. If someone knows ( probably Loren ) if that is the case in the Porsches and which sensor does what , it may give you a bit more information since you say you are smelling gas .. All the best .
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
somewhere in the neighborhood of 950 ohms, measured between the bottom 2 of the 3 terminals as mounted in the bracket.
Bentley manual has the specs.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
specs
Found it!
Page 240-14 for future reference. Per the Bently's it says test pins 25 and 26 at the dme plug socket. The range is .6 to 1.6kΩ. I have 987kΩ. So, as I read it. The ref sensor is fine. Now that leads me to the dme. How do you check "pulse voltage". Do you need a scope?
John- 78 Slick Top 930 "Illegitimi non carborundum" Last edited by sundevil64; 09-06-2013 at 07:09 AM.. |
RETIRED
You can use the BMW ones, they are like 1/2 price of the Porsche replacements.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Anyone have a part # for the bmw or application I can look up?
RETIRED
12 14 1 708 618
You can see an output for the speed sensor with a good multimeter set to AC because it happens 129 (# teeth??) times per revolution but the reference only occurs once.
Rick 88 Cab |
There is no cam sensor, the distributor routes spark to the correct cylinder. The sensors tell when the crank is at a specific position (reference ) and how fast it is turning (speed) this sensor also tracking position and speed variations during each revolution.
Rick 88 Cab Last edited by rick-l; 09-06-2013 at 09:02 AM.. |
What meter did you use.
Rick 88 Cab |
Do a search for "DME solder joints" and determine if you want to take the DME apart or send it to Ingo for test/repair.
Rick 88 Cab |
I will thanks. I have a friend that can put it under a microscope to check for small cracks.
You never did say if you had spark however. Usually fuel but no spark is a broken solder joint around the darlington transistor that controls the coil.
Rick 88 Cab |
I do not have spark. Sorry, I thought I stated that. Thanks, that will get me started. Although I have plugged another dme and it too didn't trigger a spark. I don't have a way to test either dme on another car. hmmm I wonder if I can convince someone to let me plug it into their car.
You did I missed it.
Might not be time to tear into the DME. Can you think of a way to verify the DME signal at the coil and the coil itself?
Rick 88 Cab |
