SC Heater backdate part question
Hello,
I ordered these things new from Porsche according to an older post on this forum: Right side hot air duct turbo 930.106.321.02 Left side hot air duct 911.106.327.00 Cover plate (left side) 911.106.036.00 Engine cover (left side) 911.106.827.00 Air Duct Support 911.106.331.00 http://img.photobucket.com/albums/v4...ps750ee70a.jpg but I was wondering where this part serves for: Air Duct Support 911.106.331.00 http://img.photobucket.com/albums/v4...ps03a5eb22.jpg can anyone explain please? maybe it's self-explanatory when I'm at the car, but at the moment I don't know where to put it :D Thanks! |
Sorry, can't help you, didn't need anything like it on my '78.
It screws onto the right side where I circled. The other end will screw into the engine shroud.http://forums.pelicanparts.com/uploa...1378500813.jpg
you still probably need the left side tin with a hole for the hose.
Hi John,
no need to, I chose to use the original SC-routing for the ducting: http://img.photobucket.com/albums/v4...ps1274d3be.jpg http://img.photobucket.com/albums/v4...pse868aa28.jpg other side: http://img.photobucket.com/albums/v4...ps4a540ae3.jpg http://img.photobucket.com/albums/v4...ps953ca8ad.jpg total picture: (still have to repaint the fan and housing) http://img.photobucket.com/albums/v4...ps32b4e136.jpg Greetings, Johan |
Johan,
Looks good. Where did you get the flexible hose from? How many feet did you use? |
Hi Lou,
it's actually brake ducting used for racing and can withstand temperatures up to 290°C. I think you can buy it in every racing-shop. I used about 2 metres, maybe a bit less. Greetings, Johan |
60mm V9 Orange: Biesheuvel Autosport
this is the shop over here in Europe, but I'm sure you can have these in the US too. |
Thanks for the info!
Is the original black covered aluminum ductwork available? To my eye, it seems to look the best in this application. The orange hose should go from the exchangers to the heater control valves.
Obviously, it works well in either place. |
Jack,
The original black covered aluminum ductwork is still available and that's what I have on mine currently. The problem with it is, it's not very flexible and touch to fit it on the left side duct using the original SC tin. I got it on but it has a slight tear in it that bugs me. It works for now. |
nice work. i have the canadian varient of hood support in my avatar.
| All times are GMT -8. The time now is 07:08 AM. |
