how to take off steering Wheel
hello - need to take off my '74 3 spoke wheel to re-wrap as the leather is twisting and soft. How does one do that? thanks
Old 05-22-2013, 03:49 PM
Banned
This has been written about MANY times on this forum.
There's even a how-to in the tech articles section, IIRC.
Old 05-22-2013, 03:54 PM
will search, thanks
Old 05-22-2013, 04:04 PM
Northern Motorhead
wildcat077's Avatar
Drew,
You need to pull of the horn pad and get a 1 1/16 short socket with a 8 inch 1/2 drive extension.If it has never been removed it might be a little tough to pull off but with a bit of patience and some grunt it will come off.I have a 930 steering wheel that i've renoved a few dozen times already so it takes like 30 seconds to remove and the same to reinstall ...
When you do reinstall it,stuff some paper towel in the socket so the nut sits flush with the end of the socket then slide the washer in place with an extendable magnet,hold it in place with a long screwdriver then pull the magnet off and reinstall the nut !
There you go,30 seconds or less
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 05-22-2013, 05:27 PM
winter
Winter's Avatar
When you are removing the wheel be careful, it can come off quickly and it's possible to hit yourself in the face. This has not happened to me but I got the warning from someone who bloodied themselves and their story got my attention.
Old 05-22-2013, 05:37 PM
ROW '78 911 Targa
timmy2's Avatar
Leave the nut on the last three or four threads after you crack it. then pull until wheel lets loose, remove nut, wheel slides off.
This is how to avoid a bruised face!
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-22-2013, 05:40 PM
non-whiner
mreid's Avatar
Do as Timmy says and alternate pulling the wheel from the 3:00 and 9:00 position back and forth until it pops off.
"Too much is just enough."
Old 05-22-2013, 05:47 PM
Functionista
manbridge 74's Avatar
And if it is stuck real good have a 2nd person tap steering shaft using a hammer and extension while your are pulling and nut is 3 or 4 threads from end.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 05-22-2013, 05:59 PM
Wer bremst verliert
JohnJL's Avatar
This.
I like the loctite freezenspray stuff too, you cant really heat things up in there to help work it loose and Kroil/PB Blaster stinks for a long time after.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 05-22-2013, 06:25 PM
80-911SC's Avatar
use a club type device to hold the wheel and DO NOT USE THE STEERING WHEEL LOCK TO HOLD .. you will jack up the lock ... search and you will find that also ...
Old 05-22-2013, 07:12 PM
T77911S's Avatar
the way i was taught when i worked on cars was to use one knee on one side of the steering wheel and then put a ball peen hammer under the other side with the head on the nut on the shaft and your leg inder the handle. pulling up with both legs whack the head of the hammer.
sterring wheel should pop right off.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-23-2013, 03:52 AM
83 Targa
Electric impact gun and deep socket works like a champ.
Old 05-23-2013, 01:49 PM
El Duderino
tirwin's Avatar
+1
Reduces the chance you will dork up the steering wheel lock or other damage. If you don't have one, use the club method.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 05-23-2013, 02:05 PM
Taking it apart is easy
Jerome74911S's Avatar
+ 2 on this. The nut came right off, then the wheel popped off my '74. Electric impact guns are cheap and often useful.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 05-23-2013, 02:15 PM
porwolf's Avatar
+3 on the electric impact gun. But be careful, hold it tight, it has a huge torque. Also works on the alternator pulley nut.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 05-23-2013, 02:26 PM
autobonrun's Avatar
Originally Posted by wildcat077 View Post
Drew,
I'm going to do this exercise today. 1 1/16" converts to about 25.5mm. Since I'm going to have to purchase a socket, I'd like to buy another in metric size to keep around. Has anyone confirmed a 27mm will work without being too loose? Assuming they make a 27mm.
Followup: 27mm is the correct metric size. I used an impact gun to remove the nut in a few seconds. Luckily the steering wheel slid off just as easy. However, I notice that the turn signal switch is loose and flopping around in the housing. I might as well fix that while everything is off; need to search for how to remove the housing.
1979 Porsche 911SC Targa
1996 Porsche 993 C4S
2005 Porsche 996 Turbo S
2020 BMW X3M Competition
2003 BMW M5
Old 09-07-2013, 07:53 AM
