Brew Master
cabmandone's Avatar
Smoke, Smoke and more Smoke but not coming out of exhaust
Okay, so I got my 3.2 running, took it for a shake down cruise, pulled it back in my shop and the smoke was rolling off this thing and I don't mean just a little, it filled my 30x50 shop. I started the car up again today and let it warm up after doing some component checks and poof! smoke is rolling again. I got under the car and looked around but didn't see any visible oil leaks. There was smoke coming off the heat exchangers and at the time, I had the tube that ties the exchangers together off and smoke was coming from inside the exchangers. Smoke also appeared to be coming from the alternator fan housing but it wasn't electrical smoke. After installing the engine and getting it running, I found a leaking oil return tube and replaced it. That is the only visible leak I've found. There are no oil spots on the floor whatsoever. I'm a little baffled but not discouraged.
Some history:
I have no idea how many miles are on this engine. I was told when I bought the donor car that the engine has sat for about 6 years. I was told by a few Pelicans to expect smoke but I expected smoke from the tailpipe not everywhere else.
Should I strap in a fire extinguisher and take her for a run?
Old 09-09-2013, 01:06 PM
Did you overfill it with Oil?
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 09-09-2013, 01:17 PM
If not that, could mice have placed dog food(or the equivalent) in your heat-exchangers?
Old 09-09-2013, 01:18 PM
Brew Master
cabmandone's Avatar
smoke
9 quarts from completely empty. I believe the proper amount is 10??
Old 09-09-2013, 01:48 PM
Did the engine sit around for a long time ??
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-09-2013, 02:02 PM
Brew Master
cabmandone's Avatar
Something like 6 years. Is there a thermostat or some oil fitting on the top side of the engine under the shroud? I'm getting a fair amount of smoke coming from the fan area. I'm not sure if it is working its way up through the heads and out or if it is actually coming from that area.
Old 09-09-2013, 03:34 PM
Porchcar guy's Avatar
Took about 20 minutes for my 72 to clean itself out after almost a year at the paint shop...don't ask :=)............Drive it at night for about a 1/2 hour and hopefully this will all clear out.
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 09-09-2013, 04:10 PM
It is likely the oil residue from years of drip, collecting around the heads and cylinder fins, and now just burning off. But, the car will need to be driven hard for an hour before this stuff clears up.
Old 09-09-2013, 04:21 PM
docrodg's Avatar
Late night mosquito killing drive.... it is a public service!
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 09-09-2013, 05:13 PM
Brew Master
cabmandone's Avatar
Hey, once I've got this thing licensed you won't have to tell me that one twice!
Old 09-09-2013, 05:30 PM
Northern Motorhead
wildcat077's Avatar
Look around your crank breather hose on the engine,is it connected ???
Many oil leak culprits in that general area !
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 09-09-2013, 05:37 PM
makotosun's Avatar
This is pretty basic, but is you fan belt OK?
Mine broke (old) the other day and the symptoms sound exactly like yours. Mine had some oil residue that started to smoke as the motor warmed. Kind of a white smokey stuff. Disappeared with a new belt.
No real oil leaks needed
SCWDP member #0034
'67 912 Restoration/Mod - SOLD
'80 911SC Targa -
Old 09-09-2013, 05:54 PM
Brew Master
cabmandone's Avatar
Fan belt is new. Smells like oil, but I appreciate the input.
Old 09-09-2013, 05:58 PM
Brew Master
cabmandone's Avatar
Cheers
Phil
I'm looking around for any source of a leak. At the risk of sounding like a newb (which btw I am completely) where's the tube located and where are the connection points.
Also, I've been busy sorting out my car. Once I get some time, I'll get you those pictures of the hood I told you I'd get.
Okay, just did a search and I think I found the location. I'm fairly certain I connected that hose but I'll go back and look. Could be a cracked hose??
Old 09-09-2013, 06:00 PM
Northern Motorhead
wildcat077's Avatar
Nick,
My hose was cracked at the clamp where it connects to the engine,i got black flagged at an event last year because i was leaving a James Bond style smoke cloud around the track ...
Turns out you couldn't see it because it was on the side facing the firewall and it was only leaking under load (full throttle),i managed to figure it out and cut two inches and reconnected it.
No problem for the hood,there's no rush ...
Cheers
Phil
Cheers
Phil
Old 09-09-2013, 06:24 PM
muck-raker
kidrock's Avatar
Cabmando,
Here's a picture of the oil crankcase breather (has a white rag stuffed into the breather), along with a couple of other common demon leak spots (otherwise known as the "Triangle of Death").
Otherwise, drive it like you stole it, and the smoke will probably dissipate in a short while.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 09-09-2013, 07:43 PM
Brew Master
cabmandone's Avatar
Originally Posted by kidrock View Post
Cabmando,
Checked both those spots with an inspection mirror and everything looked dry. I'm going to wait to get my plates and take it for a little cruise (with the top down naturally) and see if I can get the thing to dry up. If not, I'll keep looking.
Thanks for the help everyone and I'll post if I find anything other than residual oil being the problem.
Old 09-10-2013, 02:10 PM
Brew Master
cabmandone's Avatar
Well, looks like just driving it worked! I started it, let it warm up, checked the oil and then let it run for about 15 minutes and it didn't smoke a bit when I shut it off.
MAN! it's hard to not worry when they smoke like that but I should have listened to the wise Pelican that told me not to worry originally.
Old 09-11-2013, 05:55 PM
muck-raker
kidrock's Avatar
at this point, I'd take her out regularly for a couple of days, rack up about 100 miles or so, then take her out for a nice hot spin and give her an "Italian Tune Up". Get those RPM's up and really burn off the extra carbon and crud.
STONE
Old 09-11-2013, 06:36 PM
