wannaporsche
Removing 80SC Power Mirror switch
Does this thing just pop out like the power window switches, or is it more complicated? I don't want to break anything... but need to dislodge it to remove door panel.
Old 09-12-2013, 03:56 PM
Chief Head Scratcher
kerthunk's Avatar
The flat part on the top unscrews from the switch. You need to use snap ring pliers or something similar to put into the holes and unscrew it. The body of the switch will then fall into the door.
John Morris
'79 911SC
Old 09-12-2013, 04:17 PM
wannaporsche
Thanks!!
Old 09-12-2013, 05:19 PM
theiceman's Avatar
i use a fine pair of needle nose
be very careful re-tightening. its only plastic and breaks easily
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 09-12-2013, 07:46 PM
Cooper911SC's Avatar
To remove door panel cap, you don't need to remove the power mirror "joy stick"! It will unplug at a 4pin connector underneath.
1) Unscrew the plastic tip/cover from the door lock rod that pokes through the cap piece.
2) At the rear of the door panel cap piece remove the small plastic plug, and then unscrew the phillips head tapping screw.
3) On 911s up to '86, At the front of the door remove the phillips head tapping screw.
'87 onwards remove the single screw for plastic trim cover, then 2X tapping screws for bracket to door.
4) Gently lift the cap piece up and you will expose the back side of the power window "joy stick" Unplug the 4pin connector and remove the cap.
Cooper
Old 09-12-2013, 09:35 PM
