1977 911S
Wood?!? Is this normal...
Update -- I just heard back from the seller... he last had the oil changed 2000 miles ago when he bought the car SEVEN YEARS AGO.
______________________________________
Hi Everyone,
I'm a total newbie and learning a lot as I read through the threads on this forum. I"m a BMW fanatic who has always wanted a Porsche and I've started my search.
I looked at a 1977 targa today (I know 77 - ug). It's a bit of a Frankenstein car -- had panels from an '88 and has been repainted. Owner knows very little about the car or cars it general - he bought it seven years ago as a mid-life crisis car and has driven only 2000 miles in that time. It has service records since day one. I looked them over and it seems whoever owned it in the mid nineties spent a fortune on it. Rebuilt engine at that time and only 20k miles have elapsed since then (a lot of time). It's leaking oil.
As I was looking the car over I pulled back the floor carpet and noticed this wood below the pedals. IS THIS NORMAL??? I was planning to have the car inspected but am currently wondering what is up with this wood as it seem odd to me. Your comments are welcome.
The car pulled really strong. Although that is the first time I have even driven a Porsche.
Looks like:
Old 09-07-2013, 09:38 PM
The wood is normal but the bungee is not.
Old 09-07-2013, 09:44 PM
Wood is absolutely normal, as far as I know. My 81 has it, too.
Looks like a cool car!
Old 09-07-2013, 09:45 PM
Reiver
Reiver's Avatar
Yes, normal. There are false wood floorboards on either side. The unibody tub drops off abruptly and the floorboards give a slanted surface and cover some components.
They usually show wear (30+/- years old). There are alloy and carbon fiber replacements aftermarket...or stock wood (light).
Yes that is Pasha cloth
redstack's Avatar
Well I'll wait for the more experienced. But yea that is supposed to be wood there. And I like the color.
I'm sure there will be more comments.
Old 09-07-2013, 09:46 PM
1977 911S
Thanks for the fast replies. Glad to know the wood is normal.
The bungee was odd but I wasn't too worried about it.
Thoughts on an engine rebuild from 20 years ago>?
Thoughts on the leaking oil?
I really like the color as well - unfortunately, it's not original as the car started out life brown.
Thanks again!
Old 09-07-2013, 09:50 PM
Reiver
Reiver's Avatar
Find a good indy shop and get a PPI done....lots of info on proper PPI's. With a leak down and inspection they can give you a pretty good idea about the status of the engine...a good indy Porsche shop knows what to look for on the different models.
Hard to tell where that leak originates but when you do a PPI they'll find it for you....a leak on the Metzger engines is very normal btw and 'could be' a simple fix (oil return/sending unit seal)...or not (case/head/jugs).
Old 09-07-2013, 10:10 PM
porwolf's Avatar
My all original 1979 SC certainly has plywood floor boards on both sides.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 09-07-2013, 10:12 PM
French Import
zippy_gg's Avatar
Balsa wood is very light weight and Porsche considered it a good fit for a sports car where weight reduction is critical.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 09-07-2013, 11:30 PM
fred cook's Avatar
Are you sure...........
that the car is not a 1978 SC? Looking at the engine, the air injection pump is there and everything else looks like stock early SC hardware. It could have been a very early SC (they were sold from 1978 - 1983) in which case it would have the more desirable 3.0 liter engine. If that is the case, then the body panels would be stock Porsche.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 09-08-2013, 02:50 AM
Straight shooter
Lapkritis's Avatar
The wood floorboards are a bad joke by someone in Stuttgart. It goes like:
Two Germans walk into a bar.
Hanz: "vat should ve use for ze floorboard?"
Franz: "vat should we do with all ze trees from making way for ze autobahn?"
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 09-08-2013, 04:46 AM
kodioneill's Avatar
The original post said it's a 1977.
That color is Prussian Blue not available in 77.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 09-08-2013, 05:16 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
The part number of the case is 901.101.101.7R, which is a magnesium 2.7 case. An SC would have a 930.101.916.0 aluminum case part number.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 09-08-2013, 06:59 AM
You want to see bad boards this just came out of my 76 targa. have only had it a couple months
Old 09-08-2013, 07:17 AM
al lkosmal's Avatar
mid-year
[QUOTE=SpenceRx;7644652]Hi Everyone,
Greetings.................I'm on Porsche #5. My 1st was a 77 Targa. I drove it almost daily and kept if for 15 years. I've since had a 71E, a 73T/hotrod, 66-912 and a 70-914. All of them were/are awesome, but the 77S may have been my favorite overall driver. The mid-years cars got a bad rap for pulling head studs, etc, due to the thermal reactor emissions stuff, but most have had that corrected, engines rebuilt, etc. by now. (although it appears that your car may still have all that stuff)
These are great cars, retaining some of the early, lightweight, narrow body vibe, adding better rust proofing and becoming slightly more civilized (alternately good or bad, depending on what day it is).
I think that these cars, along with 914s will become the next big thing...now that long-hood prices have gone through the roof
regards,
Al
RGruppe #669
http://www.x-faktory.com/
Old 09-08-2013, 08:57 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Wood as a material is actually very fine choice, strong, lightweight and flexible. I guess the wood boats, airplanes and bridges of the world were colossal mistakes. This floorboard was asked to live in water without proper protection, the car it came out of had/has water leaks, which are far more problematic. I would be concerned with rust in the floorpan, pedal box area.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 09-08-2013, 09:26 AM
Straight shooter
Lapkritis's Avatar
No, it's crap just in how Porsche used it. Same with the magnesium case, aluminum cylinders and steel fasteners. This is just another bad idea.
Old 09-08-2013, 09:37 AM
Banned
^^^ Agreed - the wooden floorboards are an exercise in sheer stupidity (much like 911, non fused wiring which is plentyful).
Old 09-08-2013, 09:49 AM
It depends on who did the work and what was done. Heat, from the thermal reactors used that year and from high oil temperatures from inadequate oil cooling in some parts of the country is what killed these motors. Take the records to the shop that does the PPI and have them look through them.
Balsa is light, and Porsche did use in on some of their cars, but not for these floorboards...
That's the casting number, but your point is well made. Not a 3 liter motor...
The stupidity usually comes from the idiot owners that let too much water collect in their footwells, for too long a time. There's not supposed to be any water down there. I've never had a floorboard deteriorate, but then I take care of my cars. 35, 40 years later, they are still just fine.
JR
Old 09-08-2013, 09:56 AM
steely's Avatar
Hi Spence and welcome.
She looks great looking - and I love that color, even if she used to be brown.
I can't comment on the engine, but the floor boards might do well with some attention or replacement. Mine did not appear to see much if any water damage (although from an '87), and they did respond to some TLC, cleaning, re-glue where necessary, seal with wood protector like Thompsons. I fixed the corner damage with some epoxy and it's been holding for 5 years. before and after shots:
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 09-08-2013, 10:15 AM
