Mayonnaise on the oil Filler Cap!
New to porsche 911, have a 911t from 1969 just completed a 18months refri. Notice when checking the oil, the oil filler cap & neck has a light coating off oil mayonnaise (moisture in the oil). Car has travelled just 750miles rebuild.
Any ideas where it is coming from? (Have cleaned & powder coated the oil container).
Anybody had anything similar?
Old 09-13-2013, 05:07 PM
I'm sure it's from condensation. You need to go on longer trips and get the oil hot to burn off any moisture in the oil tank.
Old 09-13-2013, 05:18 PM
Free minder
Aurel's Avatar
The good news is, this can't be coolant water mixing with the oil, cause there ain't any water cooling .
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 09-13-2013, 06:04 PM
docrodg's Avatar
If you live in high humidity or take it out in cool we eather this can happen. Drive longer, it is a good excuse.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 09-13-2013, 06:17 PM
RETIRED
Joe Bob's Avatar
Drive it like a rental......
2012 ML350 3.0 Turbo Diesel
It usually comes from moisture inside your crankcase from cylinder blowby that mixes with your oil. It's possible your oil temperature is not getting hot enough to evaporate the moisture entering your crankcase.
Old 09-14-2013, 01:51 AM
I always take the long way wherever I'm going in either Porsche. No mayonnaise.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 09-14-2013, 03:32 AM
Tweedle,
You have the perfect excuse!
Honey i'm just going out to clear the mayonnaise out of the Porsche.
I'll be back as soon as it's gone!
Cheers
Bill
1977 Carrera 3.0
This much fun must be illegal!
Old 09-14-2013, 04:03 AM
Guardsred911's Avatar
Yes, this is the one time when the solution is to drive more, not stop and change the head gasket....
J
911 SC - 1980
911 S - 1977
Old 09-14-2013, 05:13 AM
It's called "sludge". Not visible elsewhere as well. Nasty stuff; can block oil passages and reduce heat transfer. Follow the advice given and bring engine to normal operating temp. before shutting down, or change oil more frequently.
Sherwood
Old 09-14-2013, 08:51 AM
OsoMoore's Avatar
I drive a short commute (4 miles) to work and back.
I will get this stuff building up as well, so I have taken to doing hour-long drives with the wife after dinner.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 09-14-2013, 09:04 AM
Will do! Looking forward to a good drive anyway.
Old 09-14-2013, 02:18 PM
Designer King
Paulporsche's Avatar
If the above doesn't help, you might want to try another brand of oil.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-15-2013, 09:45 AM
Like everyone said, each time you start that engine and don't get the engine and oil hot you ad moisture to the crankcase. The length of time it takes to get above boiling is exasperated by either a thermostat in great oil cooling system or a thermostat in the oil lines that doesn't open. There really is a reason that the 964s don't have an engine mounted oil cooler. By eliminating the engine mounted cooler, the thermostat in the oil lines can better do its job. When running my older 911s, I restrict the air intake in cool and cold weather, but just enough to make sure that a short 10 or 15 mile drive can get the temperatures up enough to prevent condensate. Be careful with this method, the engine you fry may be your own.
Diverdan
Old 09-16-2013, 09:13 AM
Functionista
manbridge 74's Avatar
I block my grille off (90%) as well when it is really cold.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 09-16-2013, 09:56 AM
Taking it apart is easy
Jerome74911S's Avatar
How cold is "really cold"?
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 09-16-2013, 11:13 AM
Janna James's Avatar
That is so wrong on so many levels.
Janna James
2013 Porsche 911 convertible, red, automatic/primary and 2012 BMW 750li sedan, gray, automatic/secondary
Husband's 1962 Jaguar XKE, 1971 Ferrari Daytona Spyder, 1964 Porsche 356C, 2013 Porsche Cayenne Turbo
Old 09-16-2013, 12:32 PM
Functionista
Coldest start I've had was around 5 degrees (F).
@janna ...... Nothing wrong with a little blockage when I'm driving the 5 miles it takes to run around small town doing errands.
Too cold is almost as bad as too hot, just takes longer to see the results.
One can always quickly remove blockage. Also works that there is very little stop-n-go traffic here.
It also gets the aux t-stat open, keeping the oil in the front cooler going through the system.
Jeff
74 911, #3
Old 09-16-2013, 12:48 PM
Since the water vapor rises to the highest point in the system, just remove the cap until you are cooled off.
Old 09-16-2013, 12:51 PM
the pcv system should remove the vapor in theory. once its hot enough. I dont think the 911 pcv system is effective as other engines though. since most of the oil and vapor isnt actually in the engine.
Old 09-16-2013, 03:02 PM
