MH2 MH2 is offline
911 wont start
Hello i have a 1986 911 carrera 3.2 stock and it wont start ..It only clicks battery is good ,i assume its either starter or ground but wanted to ask if i am missing something ?Thanks
Old 09-27-2013, 02:28 PM
Sounds like a bad starter solenoid.
Did you try giving it a jump? Sometimes the extra juice can kick the solenoid into engaging the starter.
Old 09-28-2013, 02:03 AM
I Wonder
mgro1959's Avatar
Second stlrj inside the solenoid there is a plate that bridges the two contact points. When you energize the solenoid by turning the key it draws this plate down to join the two contactors together and complete the circuit to roll the starter. Over time the point where plate contacts gets pitted from arcing and finally the plate will not make a good connection and starter wont turn. You will just hear a click. If you are mechanically inclined take the end plate off the solenoid and you will see what I have described. It is spring loaded so hold cover until the load is released. Usually about an inch outward. Very simple. You can sometimes get new contactors from you local starter repair place. Maybe 10 dollars for a pair. They usually are held in place with screw. Goodluck Thanks Rob
Old 09-28-2013, 02:51 AM
MH2 MH2 is offline
Thanks guys i will try that this week ..
Old 09-29-2013, 07:40 PM
