SMHemmah
hemmah's Avatar
Measure oil temp using meat temp gauge
Am I incorrect with my assumption that the best way to measure oil temp is with a meat temperature gauge in the hot oil down the oil add tube??
Assumption contributors:
Oil pressure is fast in an early engine. What is the oil pressure at 1000RPM, warm in a early Porsche engine? Around 20 PSI?
I don't have oil coolers on the front of the car - just the original oil cooler at the back of the engine. The distance from the hot engine parts and holding tank is short.
My meat temperature sensor is long and I know it is in hot oil as it sensor end is longer than my dip stick.
Opinions Please
1969 911T Body with 1970 911T 2.2L block with 911S 2.7L P&C and crank
Old 10-02-2013, 04:06 PM
SMHemmah
hemmah's Avatar
bump
Old 10-03-2013, 10:49 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
3.2 Operating temp?
A 2.7 will need an additional cooler, fender or otherwise, but you will need it if you drive remotely hard.
Oil temps?
Oil cooler details?
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 10-03-2013, 11:16 AM
Steve,
I think a thermometer would work just fine, just don't drop it in the tank!
I did almost the same thing with my MG, except I used the thermometer in the radiator to test water temp.
Or you could get an infrared temp gun and test that way.
Craig
77 Ice Green 911s w/3.0
Old 10-03-2013, 12:16 PM
This outfit makes an oil temp/gauge replacement for the dip stick.
Mainely Custom by Design - Engine Component products
Old 10-03-2013, 01:50 PM
