-   -   Bench-testing a 915 (http://forums.pelicanparts.com/porsche-911-technical-forum/771695-bench-testing-915-a.html)
Shaun @ Tru6 09-16-2013 08:10 AM
Bench-testing a 915
Is there a way to confirm that a 915 will shift properly when installed in a car, on the bench?
sundevil64 09-16-2013 08:22 AM
I have wondered the same thing short of building a stand with a seat and clutch assembly.
boyt911sc 09-16-2013 08:37 AM
Test shift after rebuild........
Shaun,
When I did my 915 rebuild many years ago and 'test shifted' the 915 transmission on the bench (less transmission fluid). But be aware that '1st gear' would be on the opposite side (5th gear) and everything is reverse location. I had a collar with handle placed on the shift lever to facilitate the shifting. With this simple method, I was able to get into different gears (1,2,3,4,5, & R). HTH.
Tony
Steve@Rennsport 09-16-2013 10:54 AM
Nope,..:(
You cannot simulate loads during a bench test; all you can do is to select gears.
Peter Zimmermann 09-16-2013 01:11 PM
Originally Posted by Steve@Rennsport (Post 7658922)
Nope,..:(
LOL! You beat me to it, I was going to write the exact same thing.
Shaun @ Tru6 09-16-2013 04:53 PM
Thank you Gentlemen, appreciate it.
Steve@Rennsport 09-16-2013 05:09 PM
HA! I got up earlier than you did,..:)
porsche930dude 09-16-2013 05:39 PM
i would just bench test it by trying every gear and make sure each one turns freely. thats really all you can do
