Shaun @ Tru6's Avatar
Bench-testing a 915
Is there a way to confirm that a 915 will shift properly when installed in a car, on the bench?
Tru6 Restoration & Design
Old 09-16-2013, 08:10 AM
I have wondered the same thing short of building a stand with a seat and clutch assembly.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 09-16-2013, 08:22 AM
Test shift after rebuild........
Shaun,
When I did my 915 rebuild many years ago and 'test shifted' the 915 transmission on the bench (less transmission fluid). But be aware that '1st gear' would be on the opposite side (5th gear) and everything is reverse location. I had a collar with handle placed on the shift lever to facilitate the shifting. With this simple method, I was able to get into different gears (1,2,3,4,5, & R). HTH.
Tony
Old 09-16-2013, 08:37 AM
Nope,..
You cannot simulate loads during a bench test; all you can do is to select gears.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-16-2013, 10:54 AM
Peter Zimmermann's Avatar
Originally Posted by Steve@Rennsport View Post
Nope,..
LOL! You beat me to it, I was going to write the exact same thing.
Keep the Shiny Side UP!
Pete Z.
Old 09-16-2013, 01:11 PM
Thank you Gentlemen, appreciate it.
Old 09-16-2013, 04:53 PM
HA! I got up earlier than you did,..
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 09-16-2013, 05:09 PM
i would just bench test it by trying every gear and make sure each one turns freely. thats really all you can do
Old 09-16-2013, 05:39 PM
