What is this connector for?
Hi Guys,
82 SC. Took my CIS off to fix some huge vacuum leaks and check everything. During breakdown I noticed a connector that wasn't connected to anything. Any ideas on what this might belong to? Thanks.
Old 11-05-2017, 12:23 PM
Flojo's Avatar
from the external air blower of heating system.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 11-05-2017, 12:32 PM
no it is for the decel thermo switch
Lorne M.
83 SC
Old 11-05-2017, 01:26 PM
Almost.........
Lorne M.
Lorne,
Maybe you meant it to be WUR (?). The decel valve does not use a thermovalve (N43) but the WUR does. Refer to circuit #104. The electrical plug for the thermovalve (N43) has brown and red/white wires.
The heater blower (V4) electrical plug in the engine bay has black and brown wires. Refer to circuit #108. Both N43 (thermovalve) and V4 (heater blower) use the same electrical plug type and easy get confuse. But the wires (color) connected to them will identify which is which.
The electrical plug posted by the OP has red/white and brown wires, so Lorne identified it correctly.
Tony
Old 11-05-2017, 02:15 PM
Can someone send me a pic of where the switch is it is supposed to connect to?
Thanks.
Old 11-05-2017, 02:38 PM
Extra electrical plug.......no picture needed.
Thanks.
The SC factory electrical engine wire harnesses for '78~ '83 are identical. However, USA spec like yours does not use a thermovalve. So this is not utilize for your specific SC. Just tack it somewhere and just be aware it is for a thermovalve. Ignore this plug.
Tony
Old 11-05-2017, 02:53 PM
Tony
Awesome! Thanks Tony. Peeps have said it before but I'll say it again...you are such an asset to our community and so generous with your time and advice. Thanks again!
Old 11-05-2017, 03:07 PM
Correction........
Lorne,
Tony
Edit:
The heater blower plug is different from that used for thermovalve. The plug posted by the OP is for the thermovalve.
Old 11-05-2017, 03:12 PM
ROW '78 911 Targa
timmy2's Avatar
Edit:
It is the Vacuum Thermovalve connector.
All 78 and 79’s use it, all Euro cars to ‘83 use it.
Not used on Lambda cars.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-05-2017, 03:29 PM
