Originally Posted by Chineras
(Post 7666524)
I have a 2004 911 4S (996) with a cracked cylinder. I am having the engine rebuilt by an outfit in LA called Vision Motors. They have asked if I would like to bore it out, put in chromoly sleeves and up the displacement to 4.0L or 4.2L.
Question: Is this a good idea? Will the rest of the car be able to handle the extra HP? Should I upgrade the oil cooler or add a performance clutch? How about the deep oil sump?
Any thoughts or advice would be appreciated
If it's cracked and your gonna repair the engine, sure, why not!
It won't cost you much more than a set of pistons, you might need new pistons anyway.
Maybe stay away from the extreme 4.2, haven't seen more than 4.1 before, might be stretching it too much.
The rest of the car will handle it, no problems, but you will need to reprogram the chip or put in a piggyback.
