Won't run after fuel leak fire MFI Webers
Looking for last ditch help. A few months ago I put MFI back on my '69 E and it ran sporadically good and bad. While moving across town to new home the car lost power due to fuel leak from MFI line and had fire on heat exchangers. No damage or fire above engine tin on top half of engine or electrics.
After replacing line vehicle started but would only run at half throttle turning over +/- 900 rpm. If you gave it any more throttle it would bog down and die. I have now replaced all MFI back to Webers that were working perfectly when removed but have similar half throttle 900 rpm issues.
What have I done???? More importantly, how do I get this car back on the road? Fuel delivery is good. Other than that I can't find a thing amiss.
Coil issues? I have Pertronix.
Thanks,
Matthew
1969 911E SOLD
2002 996 Cabrio
1995 993 Carrera 4 SOLD
Old 09-15-2013, 04:57 PM
47silver's Avatar
fuel spark air
the engine sounds like it is starving for fuel as you have spark and combustion.
did you check your fuel filter? To me something is restricting your fuel flow. you have enough to run the car but not enough to increase the speed.
1975 911S Targa
Silver Anniversary Edition
Old 09-15-2013, 05:09 PM
Plenty of fuel. I've pulled off lines and checked amount at pump and before carbs.
1969 911E SOLD
2002 996 Cabrio
Old 09-15-2013, 06:23 PM
kugelfischer's Avatar
I'm going to assume that your using the MFI specific electric fuel pump and not the same one you had running the carbs?
1973 Coupe
Projekt X (AKA bunch o' boxes full of parts)
Old 09-15-2013, 07:51 PM
ROW '78 911 Targa
timmy2's Avatar
If fuel delivery is good, that leaves spark and compression to deal with.
Are you getting a food strong spark? Put a timing light on each spark plug wire and check all are good.
Old 09-15-2013, 08:04 PM
Will check plug wires next.
Using MFI specific fuel pump but switched back to carb type pump when put carbs back on car.
thanks.
1969 911E SOLD
2002 996 Cabrio
Old 09-16-2013, 05:54 AM
BoxsterGT's Avatar
Porsche Crest
Only half throttle w both systems...........
Ck fuel supply under load. Look at the screen in the fuel tank outlet. Sometimes this gets partly blocked to allow only enough fuel to run at low speeds. Once under way or more throttle is applied it runs out of fuel & dies.
Just my 2 cents worth of advice.
Len
Old 09-16-2013, 06:04 AM
47silver's Avatar
sounds like fuel deprivation to me too.
1975 911S Targa
Old 09-16-2013, 08:55 AM
docrodg's Avatar
Float level and pressure check too. But fuel strainer sounds most likely.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 09-16-2013, 10:21 AM
It was melted Pertronix. When I removed the round pickup it came apart and the other piece had a grove melted into it. Replaced with new unit from Pelican and started right up.
Thanks to all that responded
1969 911E SOLD
2002 996 Cabrio
Old 09-21-2013, 06:33 PM
ROW '78 911 Targa
timmy2's Avatar
Good find, no spark....
Old 09-21-2013, 06:40 PM
