Was there recent transmission work done? It appears to me that the red creeps along the entire gasket joint. Could that be Loctite gasket sealant?
Old 09-24-2013, 08:17 PM
joefrantz's Avatar
Good point. It also looks too dry to be a leak.
Have you seen any spots on the floor beneath it?
Squeeze out from a red gasket cement seems like a plausible explanation.
You need to have a conversation with whoever serviced the trans.
Joe Frantz
73 911 T
Old 09-24-2013, 10:42 PM
joefrantz's Avatar
Another thought:
Pull the filler plug.
Dip finger.
Compare colors.
Joe Frantz
73 911 T
Old 09-24-2013, 10:50 PM
proffighter's Avatar
I used once some spray sealent for paper gaskets (Sure Tack or so) and it looked similar...
Roland
930 Turbo '81 Too many modifications to list
Old 09-25-2013, 12:26 AM
tylerfarner's Avatar
Thanks All for the feedback...the first "coolant" comment actually made me pause! The gearbox was recently out (twice) and serviced. I did not mention that this is a race car (PCA E Class)...not sure of that is relevant. I have an email into the shop/mechanic. There are spots on the floor, but it is relatively dry...odd to me because you can see how fresh it is on the car. Maybe a very slow drip. Thanks again for all the help...
Old 09-25-2013, 04:25 AM
